Error when importing Transient Structural results into CFD-Post
    • JureZe
      I have results from a FSI simulation, corresponding to a Transient Structural analysis and would like to visualize them together with Fluent results in CFD-Post. When I try to load mechanical results into the CFD-Post, I get an error message: "Failed to make geometry for domain 'Deafult domain'.", and no results get imported.
      I have noticed this problem only when using 2nd order shell elements in mechanical. When I did a test run with linear shell elements, results were imported just fine.
      Is there a solution for this problem or maybe an alternative way of visualizing Fluent and Transient Structural results together?
      Jure
    • Tolga
      Hi Array ,
      I am having a similar problem. Have you solved yours?
      Sincerely,
      Tolga.
  • The topic ‘Error when importing Transient Structural results into CFD-Post’ is closed to new replies.
