Error when i import a case file from one System to another
    • varun.v.c.200111
      Whenever I copy a case file from my laptop (running Ansys Fluent 2025 R1) to my institute's system (running Ansys Fluent 2024 R1), it reads the file properly (mesh, settings). I can also initialize, but when I start the calculation, I get this error in the console: "chip-exec: function  "none" not found."
      In ChatGPT, Perplexity, and Gemini are saying that it is due to UDF, but this error is occurring for cases having UDFs and not having UDFs(note: both are different case files done for different domains )
      Please help me with this .
      There will be a model setting somewhere that's not present in 24R1. Fluent will usually run with a chip-exec warning but loading into an older solver version isn't supported so isn't recommended.
