TAGGED: 2-way-fsi, ansys-fluent, system-coupling, transient-structural
April 7, 2026 at 2:41 pm
paula.dreiner
SubscriberHi everyone,Â
I'm trying to get into Fluent, specifically for 2-way FSI later on (for reference, I'm using R2025.2 with an academic license).
I've been following this tutorial (as seen in the picture) https://innovationspace.ansys.com/knowledge/forums/topic/tutorial-system-coupling-tutorial-oscillating-plate-with-two-way-fluid-structure-interaction-using-fluent-r17-2/ /
and have ran into some issues when starting the solution.ÂThe System Coupling Element is awaiting connection from the participants and then throwing an error:
"System coupling solution stopped before all participants connected. A
solver failure occurred during the run in the Fluid Flow (Fluent) system" Â ÂBeforehand, these are the warnings I'm getting:
| Warnings were found during data model validation.                   Â
| Warning: Participant Fluid Flow (Fluent) (Solution) has the             Â
| ExecutionControl 'Option' set to 'ExternallyManaged'. System Coupling Â
| will not control the startup/shutdown behavior of this participant.       Â
| Warning: Participant Transient Structural (Solution 1) has the       Â
| Warning: Unused input variables ['Force_Density'] (FDNS) on region FSIN_1Â Â
| for Transient Structural (CouplingParticipant:Solution 1).       ÂI'm not quite sure how to fix this. So far, I've tried changing from Fluid Solid Interface to System Coupling Region and turning off the license sharing. Neither changed anything. Grateful for any help.
CheersÂ
5939
1307
