December 17, 2025 at 2:57 pm
youssef.badran
SubscriberHello,ÂI am trying to Couple Rocky and Fluent on a supercomputer.
Through the Rocky interface, I selected Help -> Tutorial Workshops -> 14.Tutorial - Fluidized Bed -> Downloaded the dem_tut14_files.zip file from section 14.1.5.
Then, from Rocky interface, File -> Open project -> selected the file tutorial_14_B_pre-processing-restart.rocky in dem_tut14_files\dem_tut14_files\tutorial_14_B_pre-processing\
But I got the attached errors (error_1 appears first).
Could you please inform me how to solve this issue ?
error_1:
error_2:
error_3: -
December 18, 2025 at 11:14 am
Jackson Gomes
Ansys EmployeeHi Youssef,
Check if you have a version of Fluent compatible with Rocky installed in one of the locations indicated in the first error message.
Hope this helps!Â
If you'd like to explore more learning materials about Rocky software, you can find them here: https://innovationspace.ansys.com/ais-rocky/
Warm Regards,
Jackson
December 18, 2025 at 2:30 pm
youssef.badran
SubscriberThank you for your response.
There is a Fluent version compatible with Rocky. How can Rocky be configured to use that Fluent for the coupling case?
1535
1386
1215
