November 20, 2018 at 9:12 am
Max4
SubscriberHi,
when I try to change a boundary type from "fluid" (inlet with velocity) to "wall" using Events, I have the following error.
Error: CAR: invalid argument [1]: wrong type [not a pair]
Error Object: ()
Maxime
November 20, 2018 at 9:36 am
Amine Ben Hadj Ali
Ansys EmployeePlease check your setup: changing the BC is working for me. You can try executing a command if you struggle with the BC change.
November 20, 2018 at 9:37 am
seeta gunti
Ansys EmployeeFluid is a cell zone condition. You can use either Fluid or Solid where as inlet is a boundary condition. Please check the boundary conditions and edit it.
Seeta
November 20, 2018 at 9:42 am
Max4
SubscriberI have an inlet and an outlet with a moving piston.
Boundary Conditions : Inlet: Velocity
                      Outlet: Pressure
I want to close the outlet for a time t1 (Outlet to Wall) and then open it at a time t2. What should I use for Type when I want to change the Outlet from Wall to Outlet with pressure?
What do you mean by " Setup " ?
Maxime
November 20, 2018 at 10:04 am
Forum ModeratorYou're looking for a pressure-outlet for the type in your post above.Â
The original error means you've missed a setting somewhere: ie the wall doesn't have a temperature on it or similar. You should still be able to work with the case so look through all of the panels for a missing input. If you have an injection what was that attached to?Â
November 20, 2018 at 10:15 am
November 20, 2018 at 10:33 am
Max4
SubscriberThank you for your answers. The simulation is still running, but a problem persists in the changing of the boundary type. What may I use (Type) to change the outlet from Wall to an outlet with a pressure?
" alt="" width="271" height="319">
Indeed, I have define at the beginning the outlet (pressure 0 Pa). At t=0s, it changes to Wall, and at t=0.033s, it should change from Wall to the oulet with pressure, which was define at the beginning.
Maxime
November 20, 2018 at 11:49 am
Forum ModeratorHaving looked & checked with a colleague the Define Event method you're using won't work. If you want to switch to an inlet you'll need to use a TUI (text window) command in the event. That command will start with
/define/boundary .......................  Â
Type that into the TUI and use Enter to show the available commands & q to move back up a level.Â
November 20, 2018 at 11:55 am
Max4
SubscriberI noticed this, and as a result I'm writing a Scheme file and then loading it to finally use with TUI Commands.
Thank you for taking the time to check this.
Maxime
August 18, 2023 at 10:11 am
saeideh hadavand
Subscriberi have the same problem.. i uploaded the case and data to the remote computer and try to run it in fluent, but yet i have this problem and have no idea what your proposed solution means... this error even happens when im defining materials again... on boundary conditions as well... initialization on the inlet shows no information that is defined as boundary condition..
August 18, 2023 at 11:57 am
Forum ModeratorPlease create a new Post/Thread and add in more details, including the exact error message.Â
- The topic ‘Error using Events’ is closed to new replies.
5069
1771
1387
1248
