LS Dyna
LS Dyna
Error using ALE_STRUCTURED_FSI for S-ALE problem
    • Caleb Wood
      I am trying to model a wave tank in LS-DYNA using the Structured ALE (S-ALE) method. So far my model consists of the structured ALE mesh, half composed of water and half composed of air, and a rigid piston composed of shell elements with a prescribed motion. The model runs fine up until I add the keyword ALE_STRUCTURED_FSI, which gives the following errors (taken directly from LS-RUN):
      Beginning of keyword reader 07/24/23 19:09:09
      *** Error 10450 (KEY+450)
      in keyword command:
      *ALE_STRUCTURED_FSI_TITLE
      At line# 128 of file
      F:\Name\LS-DYNA\S-ALE\S-ALE.k
      *** Warning 10435 (KEY+435)
      lines being skipped - See messag or d3hsp files
      *** Error 10133 (KEY+133)
      input data failed with: 1 errors
      E r r o r t e r m i n a t i o n 07/24/23 19:09:25
      For reference, here is line 128 of my file (with added spaces for clarity):
      $# coupid title
      1 Piston-to-Water
      $# lstrsid    alesid     lstrstyp     alestyp     -     -     -      mcoup
                4           1                1               1                                -102
      $# start           end              pfac             fric           -            flip
              0.0         100.0               0.1              0.0                          0
      In the above, lstrsid = 4 = Rigid Piston, alesid = 1 = S-ALE mesh, mcoup = -102 = AMMG for water only (not air).
      Can anyone explain why I am getting this error, and how to fix it? Any help will be GREATLY appreciated. Thank you!
    • Caleb Wood
      ****************************************UPDATE************************************
      I added all the required keywords needed to make my model function as intended, and now there is a total of 7 errors present, shown below:
       Beginning of keyword reader                                   07/25/23 14:17:48
       *** Error 10246 (KEY+246)
           line contains improperly formatted data
            reading *ALE_STRUCTURED_MESH cards
                At line# 131 of file
       F:\Caleb\LS-DYNA\S-ALE\S-ALE_Rebuild.k
       ALL                0
                At line# 136 of file
       BOXCOR             0         1
           in keyword command:
      *ALE_STRUCTURED_FSI
                At line# 137 of file
       *** Error 11021 (KEY+1021)
             The # 2 ALE_STRUCTURED_MESH card has a starting
               node id 2, smaller than the maximum
               node id 1077350
       *** Error 11026 (KEY+1026)
             The # 3 ALE_STRUCTURED_MESH card has a
               duplicate part id 0 already used by the 5th part.
             The # 3 ALE_STRUCTURED_MESH card has a starting
               node id 1, smaller than the maximum
               node id 1077350
       *** Error 10176 (KEY+176)
           repeated part ID 0
           input data failed with: 7 errors
       E r r o r   t e r m i n a t i o n                             07/25/23 14:18:04
      Any help with these errors is greatly appreciated. Also, the .k file is saved as version R14 and is attached.
      *********************************************************** .k FILE *******************************************************
      $# LS-DYNA Keyword file created by LS-PrePost(R) V4.9.12-16Dec2022
      $# Created on Jul-25-2023 (14:15:14)
      *KEYWORD
      *TITLE
      $#        title
      LS-DYNA keyword deck by LS-PrePost
      *CONTROL_ALE
      $#     dct      nadv      meth      afac      bfac      cfac      dfac      efac
               1         1         2       0.0       0.0       0.0       0.0       0.0
      $#   start       end     aafac     vfact      prit       ebc      pref   nsidebc
             0.01.00000E20       1.01.00000E-6         0         0       0.0
      $#    ncpl      nbkt    imascl    checkr    beamin   mmgpref    pdifmx   dtmufac
               1        50         0       0.0       0.0         0       0.0       0.0
      $# optimpp    ialedr    bndflx    minmas
               0         0         01.00000E-5
      *CONTROL_TERMINATION
      $#  endtim    endcyc     dtmin    endeng    endmas     nosol
            15.0         0       0.0       0.01.000000E8         0
      *CONTROL_TIMESTEP
      $#  dtinit    tssfac      isdo    tslimt     dt2ms      lctm     erode     ms1st
             0.0       0.6         0       0.0       0.0         0         0         0
      *CONTROL_UNITS
      $#  length      time      mass      temp
      m         sec       kg        k
      *DATABASE_BINARY_D3PLOT
      $#      dt      lcdt      beam     npltc    psetid
            0.01         0         0         0         0
      $#   ioopt      rate    cutoff    window      type      pset
               0                                       0         0
      *BOUNDARY_PRESCRIBED_MOTION_SET_ID
      $#      id                                                               heading
               0Piston Motion
      $#    nsid       dof       vad      lcid        sf       vid     death     birth
               1         1         2         1       1.0         01.00000E28       0.0
      *LOAD_BODY_GENERALIZED_SET_PART
      $#    psid        n2      lcid    drlcid        xc        yc        zc
               1         0         2         0       0.0       0.0       0.0
      $#      ax        ay        az       omx       omy       omz       cid    angtyp
             0.0       0.0      9.81       0.0       0.0       0.0          CENT
      *PART
      $#        title
      Water
      $#     pid     secid       mid     eosid      hgid      grav    adpopt      tmid
               2         2         2         2         2         0         0         0
      *SECTION_SOLID_TITLE
      Water
      $#   secid    elform       aet    unused    unused    unused    cohoff   gaskeit
               2        11         0                                     0.0       0.0
      *MAT_NULL_TITLE
      Water
      $#     mid        ro        pc        mu     terod     cerod        ym        pr
               2     998.0     -10.0       0.0       0.0       0.0       0.0       0.0
      *EOS_MURNAGHAN_TITLE
      Water EOS
      $#   eosid     gamma        k0        v0
               2       7.0  150000.0       0.0
      *HOURGLASS_TITLE
      Water
      $#    hgid       ihq        qm       ibq        q1        q2    qb/vdc        qw
               2         11.00000E-6         0       1.5      0.061.00000E-61.00000E-6
      *PART
      $#        title
      Air
               3         3         3         0         3         0         0         0
      Air
               3        11         0                                     0.0       0.0
      *MAT_VACUUM_TITLE
      Air
      $#     mid       rho
               31.0000E-12
      *HOURGLASS_TITLE
      Air
               3         11.00000E-6         0       1.5      0.061.00000E-61.00000E-6
      *PART
      $#        title
      Piston
               4         4         4         0         0         0         0         0
      *SECTION_SHELL_TITLE
      Piston
      $#   secid    elform      shrf       nip     propt   qr/irid     icomp     setyp
               4        16       1.0         2       1.0         0         0         1
      $#      t1        t2        t3        t4      nloc     marea      idof    edgset
             0.5       0.5       0.5       0.5       0.0       0.0       0.0         0
      *MAT_RIGID_TITLE
      Piston
      $#     mid        ro         e        pr         n    couple         m     alias
               4     100.0   20000.0      0.25       0.0       0.0       0.0
      $#     cmo      con1      con2
             1.0         5         7
      $#lco or a1        a2        a3        v1        v2        v3
             0.0
      $#   mshid      dpid      nbid      ebid    unused    unused    unused    tdeath
               1         1   1000001   1000001
      $#   cpidx     cpidy     cpidz      nid0     lcsid
            1001      1002      1003
      *ALE_STRUCTURED_MESH_CONTROL_POINTS
      $#    cpid    unused     icase       sfo    unused      offo
            1001                   0       1.0                 0.0
      $#                 n                   x               ratio
                         1                 0.0                 0.0
                       221                11.0                 0.0
            1002                   0       1.0                 0.0
      $#                 n                   x               ratio
                         1                 0.0                 0.0
                        14                0.65                 0.0
            1003                   0       1.0                 0.0
      $#                 n                   x               ratio
                         1                 0.0                 0.0
                        25                 1.2                 0.0
      *ALE_ESSENTIAL_BOUNDARY
      $#      id    idtype    ictype     iexcl
               1         1         1         0
      *ALE_MULTI-MATERIAL_GROUP
      $#     sid    idtype
               2         1
               3         1
      *ALE_STRUCTURED_MESH_VOLUME_FILLING
      $#   mshid    unused    ammgto    unused   nsample    unused   unused-       vid
               1          2                            3                             0
      $#    geom    in/out        e1        e2        e3        e4        e5
      ALL                0
               1          1                            3                             0
      $#    geom    in/out     boxid        e2        e3        e4        e5
      BOXCOR             0         1
      *ALE_STRUCTURED_FSI
               4         2         1         1                                    -102
             0.01.00000E10       0.1       0.0                   0
      *DEFINE_BOX_LOCAL_TITLE
      Water Box
      $#   boxid       xmn       xmx       ymn       ymx       zmn       zmx
               1       0.0      11.0       0.0      0.65       0.0       0.6
      $#      xx        yx        zx        xv        yv        zv
      $#      cx        cy        cz
             0.0       0.0       0.0
      *DEFINE_CURVE_TITLE
      Piston Motion
      $#    lcid      sidr       sfa       sfo      offa      offo    dattyp     lcint
               1         0      0.56      0.23       0.0       0.0         0         0
      $#                a1                  o1
                       0.0                 0.0
                       1.0                 1.0
                       2.0                 0.0
                       3.0                 1.0
                       4.0                 0.0
                       5.0                 1.0
                       6.0                 0.0
                       7.0                 1.0
                       8.0                 0.0
                       9.0                 1.0
                      10.0                 0.0
                      11.0                 1.0
                      12.0                 0.0
                      13.0                 1.0
                      14.0                 0.0
                      15.0                 1.0
                      16.0                 0.0
                      17.0                 1.0
                      18.0                 0.0
                      19.0                 1.0
                      20.0                 0.0
                      21.0                 1.0
                      22.0                 0.0
                      23.0                 1.0
                      24.0                 0.0
                      25.0                 1.0
                      26.0                 0.0
                      27.0                 1.0
                      28.0                 0.0
                      29.0                 1.0
                      30.0                 0.0
      *DEFINE_CURVE_TITLE
      Gravity
               2         0       1.0       1.0       0.0       0.0         0         0
      $#                a1                  o1
                       0.0                 1.0
                     100.0                 1.0
      *ELEMENT_SHELL
      $#   eid     pid      n1      n2      n3      n4      n5      n6      n7      n8
             1       4      15       1       2      16       0       0       0       0
             2       4      16       2       3      17       0       0       0       0
             3       4      17       3       4      18       0       0       0       0
             4       4      18       4       5      19       0       0       0       0
             5       4      19       5       6      20       0       0       0       0
             6       4      20       6       7      21       0       0       0       0
             7       4      21       7       8      22       0       0       0       0
             8       4      22       8       9      23       0       0       0       0
             9       4      23       9      10      24       0       0       0       0
            10       4      24      10      11      25       0       0       0       0
            11       4      25      11      12      26       0       0       0       0
            12       4      26      12      13      27       0       0       0       0
            13       4      27      13      14      28       0       0       0       0
            14       4      29      15      16      30       0       0       0       0
            15       4      30      16      17      31       0       0       0       0
            16       4      31      17      18      32       0       0       0       0
            17       4      32      18      19      33       0       0       0       0
            18       4      33      19      20      34       0       0       0       0
            19       4      34      20      21      35       0       0       0       0
            20       4      35      21      22      36       0       0       0       0
            21       4      36      22      23      37       0       0       0       0
            22       4      37      23      24      38       0       0       0       0
            23       4      38      24      25      39       0       0       0       0
            24       4      39      25      26      40       0       0       0       0
            25       4      40      26      27      41       0       0       0       0
            26       4      41      27      28      42       0       0       0       0
            27       4      43      29      30      44       0       0       0       0
            28       4      44      30      31      45       0       0       0       0
            29       4      45      31      32      46       0       0       0       0
            30       4      46      32      33      47       0       0       0       0
            31       4      47      33      34      48       0       0       0       0
            32       4      48      34      35      49       0       0       0       0
            33       4      49      35      36      50       0       0       0       0
            34       4      50      36      37      51       0       0       0       0
            35       4      51      37      38      52       0       0       0       0
            36       4      52      38      39      53       0       0       0       0
            37       4      53      39      40      54       0       0       0       0
            38       4      54      40      41      55       0       0       0       0
            39       4      55      41      42      56       0       0       0       0
            40       4      57      43      44      58       0       0       0       0
            41       4      58      44      45      59       0       0       0       0
            42       4      59      45      46      60       0       0       0       0
            43       4      60      46      47      61       0       0       0       0
            44       4      61      47      48      62       0       0       0       0
            45       4      62      48      49      63       0       0       0       0
            46       4      63      49      50      64       0       0       0       0
            47       4      64      50      51      65       0       0       0       0
            48       4      65      51      52      66       0       0       0       0
            49       4      66      52      53      67       0       0       0       0
            50       4      67      53      54      68       0       0       0       0
            51       4      68      54      55      69       0       0       0       0
            52       4      69      55      56      70       0       0       0       0
            53       4      71      57      58      72       0       0       0       0
            54       4      72      58      59      73       0       0       0       0
            55       4      73      59      60      74       0       0       0       0
            56       4      74      60      61      75       0       0       0       0
            57       4      75      61      62      76       0       0       0       0
            58       4      76      62      63      77       0       0       0       0
            59       4      77      63      64      78       0       0       0       0
            60       4      78      64      65      79       0       0       0       0
            61       4      79      65      66      80       0       0       0       0
            62       4      80      66      67      81       0       0       0       0
            63       4      81      67      68      82       0       0       0       0
            64       4      82      68      69      83       0       0       0       0
            65       4      83      69      70      84       0       0       0       0
            66       4      85      71      72      86       0       0       0       0
            67       4      86      72      73      87       0       0       0       0
            68       4      87      73      74      88       0       0       0       0
            69       4      88      74      75      89       0       0       0       0
            70       4      89      75      76      90       0       0       0       0
            71       4      90      76      77      91       0       0       0       0
            72       4      91      77      78      92       0       0       0       0
            73       4      92      78      79      93       0       0       0       0
            74       4      93      79      80      94       0       0       0       0
            75       4      94      80      81      95       0       0       0       0
            76       4      95      81      82      96       0       0       0       0
            77       4      96      82      83      97       0       0       0       0
            78       4      97      83      84      98       0       0       0       0
            79       4      99      85      86     100       0       0       0       0
            80       4     100      86      87     101       0       0       0       0
            81       4     101      87      88     102       0       0       0       0
            82       4     102      88      89     103       0       0       0       0
            83       4     103      89      90     104       0       0       0       0
            84       4     104      90      91     105       0       0       0       0
            85       4     105      91      92     106       0       0       0       0
            86       4     106      92      93     107       0       0       0       0
            87       4     107      93      94     108       0       0       0       0
            88       4     108      94      95     109       0       0       0       0
            89       4     109      95      96     110       0       0       0       0
            90       4     110      96      97     111       0       0       0       0
            91       4     111      97      98     112       0       0       0       0
            92       4     113      99     100     114       0       0       0       0
            93       4     114     100     101     115       0       0       0       0
            94       4     115     101     102     116       0       0       0       0
            95       4     116     102     103     117       0       0       0       0
            96       4     117     103     104     118       0       0       0       0
            97       4     118     104     105     119       0       0       0       0
            98       4     119     105     106     120       0       0       0       0
            99       4     120     106     107     121       0       0       0       0
           100       4     121     107     108     122       0       0       0       0
           101       4     122     108     109     123       0       0       0       0
           102       4     123     109     110     124       0       0       0       0
           103       4     124     110     111     125       0       0       0       0
           104       4     125     111     112     126       0       0       0       0
           105       4     127     113     114     128       0       0       0       0
           106       4     128     114     115     129       0       0       0       0
           107       4     129     115     116     130       0       0       0       0
           108       4     130     116     117     131       0       0       0       0
           109       4     131     117     118     132       0       0       0       0
           110       4     132     118     119     133       0       0       0       0
           111       4     133     119     120     134       0       0       0       0
           112       4     134     120     121     135       0       0       0       0
           113       4     135     121     122     136       0       0       0       0
           114       4     136     122     123     137       0       0       0       0
           115       4     137     123     124     138       0       0       0       0
           116       4     138     124     125     139       0       0       0       0
           117       4     139     125     126     140       0       0       0       0
           118       4     141     127     128     142       0       0       0       0
           119       4     142     128     129     143       0       0       0       0
           120       4     143     129     130     144       0       0       0       0
           121       4     144     130     131     145       0       0       0       0
           122       4     145     131     132     146       0       0       0       0
           123       4     146     132     133     147       0       0       0       0
           124       4     147     133     134     148       0       0       0       0
           125       4     148     134     135     149       0       0       0       0
           126       4     149     135     136     150       0       0       0       0
           127       4     150     136     137     151       0       0       0       0
           128       4     151     137     138     152       0       0       0       0
           129       4     152     138     139     153       0       0       0       0
           130       4     153     139     140     154       0       0       0       0
           131       4     155     141     142     156       0       0       0       0
           132       4     156     142     143     157       0       0       0       0
           133       4     157     143     144     158       0       0       0       0
           134       4     158     144     145     159       0       0       0       0
           135       4     159     145     146     160       0       0       0       0
           136       4     160     146     147     161       0       0       0       0
           137       4     161     147     148     162       0       0       0       0
           138       4     162     148     149     163       0       0       0       0
           139       4     163     149     150     164       0       0       0       0
           140       4     164     150     151     165       0       0       0       0
           141       4     165     151     152     166       0       0       0       0
           142       4     166     152     153     167       0       0       0       0
           143       4     167     153     154     168       0       0       0       0
           144       4     169     155     156     170       0       0       0       0
           145       4     170     156     157     171       0       0       0       0
           146       4     171     157     158     172       0       0       0       0
           147       4     172     158     159     173       0       0       0       0
           148       4     173     159     160     174       0       0       0       0
           149       4     174     160     161     175       0       0       0       0
           150       4     175     161     162     176       0       0       0       0
           151       4     176     162     163     177       0       0       0       0
           152       4     177     163     164     178       0       0       0       0
           153       4     178     164     165     179       0       0       0       0
           154       4     179     165     166     180       0       0       0       0
           155       4     180     166     167     181       0       0       0       0
           156       4     181     167     168     182       0       0       0       0
           157       4     183     169     170     184       0       0       0       0
           158       4     184     170     171     185       0       0       0       0
           159       4     185     171     172     186       0       0       0       0
           160       4     186     172     173     187       0       0       0       0
           161       4     187     173     174     188       0       0       0       0
           162       4     188     174     175     189       0       0       0       0
           163       4     189     175     176     190       0       0       0       0
           164       4     190     176     177     191       0       0       0       0
           165       4     191     177     178     192       0       0       0       0
           166       4     192     178     179     193       0       0       0       0
           167       4     193     179     180     194       0       0       0       0
           168       4     194     180     181     195       0       0       0       0
           169       4     195     181     182     196       0       0       0       0
           170       4     197     183     184     198       0       0       0       0
           171       4     198     184     185     199       0       0       0       0
           172       4     199     185     186     200       0       0       0       0
           173       4     200     186     187     201       0       0       0       0
           174       4     201     187     188     202       0       0       0       0
           175       4     202     188     189     203       0       0       0       0
           176       4     203     189     190     204       0       0       0       0
           177       4     204     190     191     205       0       0       0       0
           178       4     205     191     192     206       0       0       0       0
           179       4     206     192     193     207       0       0       0       0
           180       4     207     193     194     208       0       0       0       0
           181       4     208     194     195     209       0       0       0       0
           182       4     209     195     196     210       0       0       0       0
           183       4     211     197     198     212       0       0       0       0
           184       4     212     198     199     213       0       0       0       0
           185       4     213     199     200     214       0       0       0       0
           186       4     214     200     201     215       0       0       0       0
           187       4     215     201     202     216       0       0       0       0
           188       4     216     202     203     217       0       0       0       0
           189       4     217     203     204     218       0       0       0       0
           190       4     218     204     205     219       0       0       0       0
           191       4     219     205     206     220       0       0       0       0
           192       4     220     206     207     221       0       0       0       0
           193       4     221     207     208     222       0       0       0       0
           194       4     222     208     209     223       0       0       0       0
           195       4     223     209     210     224       0       0       0       0
           196       4     225     211     212     226       0       0       0       0
           197       4     226     212     213     227       0       0       0       0
           198       4     227     213     214     228       0       0       0       0
           199       4     228     214     215     229       0       0       0       0
           200       4     229     215     216     230       0       0       0       0
           201       4     230     216     217     231       0       0       0       0
           202       4     231     217     218     232       0       0       0       0
           203       4     232     218     219     233       0       0       0       0
           204       4     233     219     220     234       0       0       0       0
           205       4     234     220     221     235       0       0       0       0
           206       4     235     221     222     236       0       0       0       0
           207       4     236     222     223     237       0       0       0       0
           208       4     237     223     224     238       0       0       0       0
           209       4     239     225     226     240       0       0       0       0
           210       4     240     226     227     241       0       0       0       0
           211       4     241     227     228     242       0       0       0       0
           212       4     242     228     229     243       0       0       0       0
           213       4     243     229     230     244       0       0       0       0
           214       4     244     230     231     245       0       0       0       0
           215       4     245     231     232     246       0       0       0       0
           216       4     246     232     233     247       0       0       0       0
           217       4     247     233     234     248       0       0       0       0
           218       4     248     234     235     249       0       0       0       0
           219       4     249     235     236     250       0       0       0       0
           220       4     250     236     237     251       0       0       0       0
           221       4     251     237     238     252       0       0       0       0
           222       4     253     239     240     254       0       0       0       0
           223       4     254     240     241     255       0       0       0       0
           224       4     255     241     242     256       0       0       0       0
           225       4     256     242     243     257       0       0       0       0
           226       4     257     243     244     258       0       0       0       0
           227       4     258     244     245     259       0       0       0       0
           228       4     259     245     246     260       0       0       0       0
           229       4     260     246     247     261       0       0       0       0
           230       4     261     247     248     262       0       0       0       0
           231       4     262     248     249     263       0       0       0       0
           232       4     263     249     250     264       0       0       0       0
           233       4     264     250     251     265       0       0       0       0
           234       4     265     251     252     266       0       0       0       0
           235       4     267     253     254     268       0       0       0       0
           236       4     268     254     255     269       0       0       0       0
           237       4     269     255     256     270       0       0       0       0
           238       4     270     256     257     271       0       0       0       0
           239       4     271     257     258     272       0       0       0       0
           240       4     272     258     259     273       0       0       0       0
           241       4     273     259     260     274       0       0       0       0
           242       4     274     260     261     275       0       0       0       0
           243       4     275     261     262     276       0       0       0       0
           244       4     276     262     263     277       0       0       0       0
           245       4     277     263     264     278       0       0       0       0
           246       4     278     264     265     279       0       0       0       0
           247       4     279     265     266     280       0       0       0       0
           248       4     281     267     268     282       0       0       0       0
           249       4     282     268     269     283       0       0       0       0
           250       4     283     269     270     284       0       0       0       0
           251       4     284     270     271     285       0       0       0       0
           252       4     285     271     272     286       0       0       0       0
           253       4     286     272     273     287       0       0       0       0
           254       4     287     273     274     288       0       0       0       0
           255       4     288     274     275     289       0       0       0       0
           256       4     289     275     276     290       0       0       0       0
           257       4     290     276     277     291       0       0       0       0
           258       4     291     277     278     292       0       0       0       0
           259       4     292     278     279     293       0       0       0       0
           260       4     293     279     280     294       0       0       0       0
           261       4     295     281     282     296       0       0       0       0
           262       4     296     282     283     297       0       0       0       0
           263       4     297     283     284     298       0       0       0       0
           264       4     298     284     285     299       0       0       0       0
           265       4     299     285     286     300       0       0       0       0
           266       4     300     286     287     301       0       0       0       0
           267       4     301     287     288     302       0       0       0       0
           268       4     302     288     289     303       0       0       0       0
           269       4     303     289     290     304       0       0       0       0
           270       4     304     290     291     305       0       0       0       0
           271       4     305     291     292     306       0       0       0       0
           272       4     306     292     293     307       0       0       0       0
           273       4     307     293     294     308       0       0       0       0
           274       4     309     295     296     310       0       0       0       0
           275       4     310     296     297     311       0       0       0       0
           276       4     311     297     298     312       0       0       0       0
           277       4     312     298     299     313       0       0       0       0
           278       4     313     299     300     314       0       0       0       0
           279       4     314     300     301     315       0       0       0       0
           280       4     315     301     302     316       0       0       0       0
           281       4     316     302     303     317       0       0       0       0
           282       4     317     303     304     318       0       0       0       0
           283       4     318     304     305     319       0       0       0       0
           284       4     319     305     306     320       0       0       0       0
           285       4     320     306     307     321       0       0       0       0
           286       4     321     307     308     322       0       0       0       0
           287       4     323     309     310     324       0       0       0       0
           288       4     324     310     311     325       0       0       0       0
           289       4     325     311     312     326       0       0       0       0
           290       4     326     312     313     327       0       0       0       0
           291       4     327     313     314     328       0       0       0       0
           292       4     328     314     315     329       0       0       0       0
           293       4     329     315     316     330       0       0       0       0
           294       4     330     316     317     331       0       0       0       0
           295       4     331     317     318     332       0       0       0       0
           296       4     332     318     319     333       0       0       0       0
           297       4     333     319     320     334       0       0       0       0
           298       4     334     320     321     335       0       0       0       0
           299       4     335     321     322     336       0       0       0       0
           300       4     337     323     324     338       0       0       0       0
           301       4     338     324     325     339       0       0       0       0
           302       4     339     325     326     340       0       0       0       0
           303       4     340     326     327     341       0       0       0       0
           304       4     341     327     328     342       0       0       0       0
           305       4     342     328     329     343       0       0       0       0
           306       4     343     329     330     344       0       0       0       0
           307       4     344     330     331     345       0       0       0       0
           308       4     345     331     332     346       0       0       0       0
           309       4     346     332     333     347       0       0       0       0
           310       4     347     333     334     348       0       0       0       0
           311       4     348     334     335     349       0       0       0       0
           312       4     349     335     336     350       0       0       0       0
      *NODE
      $#   nid               x               y               z      tc      rc
             1             0.0             0.0             0.0       0       0
             2             0.0            0.05             0.0       0       0
             3             0.0             0.1             0.0       0       0
             4             0.0            0.15             0.0       0       0
             5             0.0             0.2             0.0       0       0
             6             0.0            0.25             0.0       0       0
             7             0.0             0.3             0.0       0       0
             8             0.0            0.35             0.0       0       0
             9             0.0             0.4             0.0       0       0
            10             0.0            0.45             0.0       0       0
            11             0.0             0.5             0.0       0       0
            12             0.0            0.55             0.0       0       0
            13             0.0             0.6             0.0       0       0
            14             0.0            0.65             0.0       0       0
            15             0.0             0.0            0.05       0       0
            16             0.0            0.05            0.05       0       0
            17             0.0             0.1            0.05       0       0
            18             0.0            0.15            0.05       0       0
            19             0.0             0.2            0.05       0       0
            20             0.0            0.25            0.05       0       0
            21             0.0             0.3            0.05       0       0
            22             0.0            0.35            0.05       0       0
            23             0.0             0.4            0.05       0       0
            24             0.0            0.45            0.05       0       0
            25             0.0             0.5            0.05       0       0
            26             0.0            0.55            0.05       0       0
            27             0.0             0.6            0.05       0       0
            28             0.0            0.65            0.05       0       0
            29             0.0             0.0             0.1       0       0
            30             0.0            0.05             0.1       0       0
            31             0.0             0.1             0.1       0       0
            32             0.0            0.15             0.1       0       0
            33             0.0             0.2             0.1       0       0
            34             0.0            0.25             0.1       0       0
            35             0.0             0.3             0.1       0       0
            36             0.0            0.35             0.1       0       0
            37             0.0             0.4             0.1       0       0
            38             0.0            0.45             0.1       0       0
            39             0.0             0.5             0.1       0       0
            40             0.0            0.55             0.1       0       0
            41             0.0             0.6             0.1       0       0
            42             0.0            0.65             0.1       0       0
            43             0.0             0.0            0.15       0       0
            44             0.0            0.05            0.15       0       0
            45             0.0             0.1            0.15       0       0
            46             0.0            0.15            0.15       0       0
            47             0.0             0.2            0.15       0       0
            48             0.0            0.25            0.15       0       0
            49             0.0             0.3            0.15       0       0
            50             0.0            0.35            0.15       0       0
            51             0.0             0.4            0.15       0       0
            52             0.0            0.45            0.15       0       0
            53             0.0             0.5            0.15       0       0
            54             0.0            0.55            0.15       0       0
            55             0.0             0.6            0.15       0       0
            56             0.0            0.65            0.15       0       0
            57             0.0             0.0             0.2       0       0
            58             0.0            0.05             0.2       0       0
            59             0.0             0.1             0.2       0       0
            60             0.0            0.15             0.2       0       0
            61             0.0             0.2             0.2       0       0
            62             0.0            0.25             0.2       0       0
            63             0.0             0.3             0.2       0       0
            64             0.0            0.35             0.2       0       0
            65             0.0             0.4             0.2       0       0
            66             0.0            0.45             0.2       0       0
            67             0.0             0.5             0.2       0       0
            68             0.0            0.55             0.2       0       0
            69             0.0             0.6             0.2       0       0
            70             0.0            0.65             0.2       0       0
            71             0.0             0.0            0.25       0       0
            72             0.0            0.05            0.25       0       0
            73             0.0             0.1            0.25       0       0
            74             0.0            0.15            0.25       0       0
            75             0.0             0.2            0.25       0       0
            76             0.0            0.25            0.25       0       0
            77             0.0             0.3            0.25       0       0
            78             0.0            0.35            0.25       0       0
            79             0.0             0.4            0.25       0       0
            80             0.0            0.45            0.25       0       0
            81             0.0             0.5            0.25       0       0
            82             0.0            0.55            0.25       0       0
            83             0.0             0.6            0.25       0       0
            84             0.0            0.65            0.25       0       0
            85             0.0             0.0             0.3       0       0
            86             0.0            0.05             0.3       0       0
            87             0.0             0.1             0.3       0       0
            88             0.0            0.15             0.3       0       0
            89             0.0             0.2             0.3       0       0
            90             0.0            0.25             0.3       0       0
            91             0.0             0.3             0.3       0       0
            92             0.0            0.35             0.3       0       0
            93             0.0             0.4             0.3       0       0
            94             0.0            0.45             0.3       0       0
            95             0.0             0.5             0.3       0       0
            96             0.0            0.55             0.3       0       0
            97             0.0             0.6             0.3       0       0
            98             0.0            0.65             0.3       0       0
            99             0.0             0.0            0.35       0       0
           100             0.0            0.05       0.3500001       0       0
           101             0.0             0.1            0.35       0       0
           102             0.0            0.15            0.35       0       0
           103             0.0             0.2       0.3500001       0       0
           104             0.0            0.25            0.35       0       0
           105             0.0             0.3            0.35       0       0
           106             0.0            0.35            0.35       0       0
           107             0.0             0.4            0.35       0       0
           108             0.0            0.45       0.3500001       0       0
           109             0.0             0.5       0.3500001       0       0
           110             0.0            0.55            0.35       0       0
           111             0.0             0.6       0.3500001       0       0
           112             0.0            0.65            0.35       0       0
           113             0.0             0.0             0.4       0       0
           114             0.0            0.05             0.4       0       0
           115             0.0             0.1             0.4       0       0
           116             0.0            0.15             0.4       0       0
           117             0.0             0.2       0.4000001       0       0
           118             0.0            0.25             0.4       0       0
           119             0.0             0.3             0.4       0       0
           120             0.0            0.35             0.4       0       0
           121             0.0             0.4             0.4       0       0
           122             0.0            0.45             0.4       0       0
           123             0.0             0.5             0.4       0       0
           124             0.0            0.55             0.4       0       0
           125             0.0             0.6             0.4       0       0
           126             0.0            0.65             0.4       0       0
           127             0.0             0.0            0.45       0       0
           128             0.0            0.05            0.45       0       0
           129             0.0             0.1            0.45       0       0
           130             0.0            0.15            0.45       0       0
           131             0.0             0.2            0.45       0       0
           132             0.0            0.25            0.45       0       0
           133             0.0             0.3            0.45       0       0
           134             0.0            0.35            0.45       0       0
           135             0.0             0.4            0.45       0       0
           136             0.0            0.45            0.45       0       0
           137             0.0             0.5            0.45       0       0
           138             0.0            0.55            0.45       0       0
           139             0.0             0.6            0.45       0       0
           140             0.0            0.65            0.45       0       0
           141             0.0             0.0       0.5000001       0       0
           142             0.0            0.05             0.5       0       0
           143             0.0             0.1             0.5       0       0
           144             0.0            0.15       0.5000001       0       0
           145             0.0             0.2       0.5000001       0       0
           146             0.0            0.25             0.5       0       0
           147             0.0             0.3       0.5000001       0       0
           148             0.0            0.35       0.5000001       0       0
           149             0.0             0.4       0.5000001       0       0
           150             0.0            0.45             0.5       0       0
           151             0.0             0.5       0.5000001       0       0
           152             0.0            0.55             0.5       0       0
           153             0.0             0.6       0.5000001       0       0
           154             0.0            0.65       0.5000001       0       0
           155             0.0             0.0            0.55       0       0
           156             0.0            0.05            0.55       0       0
           157             0.0             0.1            0.55       0       0
           158             0.0            0.15            0.55       0       0
           159             0.0             0.2       0.5500001       0       0
           160             0.0            0.25            0.55       0       0
           161             0.0             0.3       0.5500001       0       0
           162             0.0            0.35            0.55       0       0
           163             0.0             0.4       0.5500001       0       0
           164             0.0            0.45       0.5500001       0       0
           165             0.0             0.5            0.55       0       0
           166             0.0            0.55            0.55       0       0
           167             0.0             0.6       0.5500001       0       0
           168             0.0            0.65            0.55       0       0
           169             0.0             0.0             0.6       0       0
           170             0.0            0.05             0.6       0       0
           171             0.0             0.1             0.6       0       0
           172             0.0            0.15             0.6       0       0
           173             0.0             0.2             0.6       0       0
           174             0.0            0.25             0.6       0       0
           175             0.0             0.3             0.6       0       0
           176             0.0            0.35             0.6       0       0
           177             0.0             0.4             0.6       0       0
           178             0.0            0.45             0.6       0       0
           179             0.0             0.5             0.6       0       0
           180             0.0            0.55             0.6       0       0
           181             0.0             0.6             0.6       0       0
           182             0.0            0.65             0.6       0       0
           183             0.0             0.0            0.65       0       0
           184             0.0            0.05            0.65       0       0
           185             0.0             0.1            0.65       0       0
           186             0.0            0.15            0.65       0       0
           187             0.0             0.2       0.6500001       0       0
           188             0.0            0.25            0.65       0       0
           189             0.0             0.3            0.65       0       0
           190             0.0            0.35            0.65       0       0
           191             0.0             0.4            0.65       0       0
           192             0.0            0.45            0.65       0       0
           193             0.0             0.5       0.6500001       0       0
           194             0.0            0.55            0.65       0       0
           195             0.0             0.6            0.65       0       0
           196             0.0            0.65            0.65       0       0
           197             0.0             0.0             0.7       0       0
           198             0.0            0.05       0.7000001       0       0
           199             0.0             0.1             0.7       0       0
           200             0.0            0.15             0.7       0       0
           201             0.0             0.2       0.7000001       0       0
           202             0.0            0.25             0.7       0       0
           203             0.0             0.3             0.7       0       0
           204             0.0            0.35             0.7       0       0
           205             0.0             0.4             0.7       0       0
           206             0.0            0.45       0.7000001       0       0
           207             0.0             0.5       0.7000001       0       0
           208             0.0            0.55             0.7       0       0
           209             0.0             0.6       0.7000001       0       0
           210             0.0            0.65             0.7       0       0
           211             0.0             0.0            0.75       0       0
           212             0.0            0.05            0.75       0       0
           213             0.0             0.1       0.7500001       0       0
           214             0.0            0.15            0.75       0       0
           215             0.0             0.2            0.75       0       0
           216             0.0            0.25            0.75       0       0
           217             0.0             0.3            0.75       0       0
           218             0.0            0.35            0.75       0       0
           219             0.0             0.4            0.75       0       0
           220             0.0            0.45            0.75       0       0
           221             0.0             0.5       0.7500001       0       0
           222             0.0            0.55       0.7500001       0       0
           223             0.0             0.6       0.7500001       0       0
           224             0.0            0.65            0.75       0       0
           225             0.0             0.0       0.8000001       0       0
           226             0.0            0.05       0.8000001       0       0
           227             0.0             0.1       0.8000001       0       0
           228             0.0            0.15             0.8       0       0
           229             0.0             0.2       0.8000001       0       0
           230             0.0            0.25       0.8000001       0       0
           231             0.0             0.3       0.8000001       0       0
           232             0.0            0.35       0.8000001       0       0
           233             0.0             0.4       0.8000001       0       0
           234             0.0            0.45       0.8000001       0       0
           235             0.0             0.5       0.8000001       0       0
           236             0.0            0.55       0.8000001       0       0
           237             0.0             0.6       0.8000001       0       0
           238             0.0            0.65       0.8000001       0       0
           239             0.0             0.0       0.8500001       0       0
           240             0.0            0.05       0.8500001       0       0
           241             0.0             0.1       0.8500001       0       0
           242             0.0            0.15       0.8500001       0       0
           243             0.0             0.2       0.8500001       0       0
           244             0.0            0.25            0.85       0       0
           245             0.0             0.3       0.8500001       0       0
           246             0.0            0.35       0.8500001       0       0
           247             0.0             0.4       0.8500001       0       0
           248             0.0            0.45       0.8500001       0       0
           249             0.0             0.5            0.85       0       0
           250             0.0            0.55       0.8500001       0       0
           251             0.0             0.6       0.8500001       0       0
           252             0.0            0.65       0.8500001       0       0
           253             0.0             0.0             0.9       0       0
           254             0.0            0.05       0.9000001       0       0
           255             0.0             0.1       0.9000001       0       0
           256             0.0            0.15             0.9       0       0
           257             0.0             0.2       0.9000001       0       0
           258             0.0            0.25             0.9       0       0
           259             0.0             0.3             0.9       0       0
           260             0.0            0.35             0.9       0       0
           261             0.0             0.4       0.9000001       0       0
           262             0.0            0.45             0.9       0       0
           263             0.0             0.5             0.9       0       0
           264             0.0            0.55       0.9000001       0       0
           265             0.0             0.6             0.9       0       0
           266             0.0            0.65             0.9       0       0
           267             0.0             0.0            0.95       0       0
           268             0.0            0.05            0.95       0       0
           269             0.0             0.1            0.95       0       0
           270             0.0            0.15            0.95       0       0
           271             0.0             0.2            0.95       0       0
           272             0.0            0.25            0.95       0       0
           273             0.0             0.3            0.95       0       0
           274             0.0            0.35            0.95       0       0
           275             0.0             0.4            0.95       0       0
           276             0.0            0.45            0.95       0       0
           277             0.0             0.5            0.95       0       0
           278             0.0            0.55            0.95       0       0
           279             0.0             0.6            0.95       0       0
           280             0.0            0.65            0.95       0       0
           281             0.0             0.0             1.0       0       0
           282             0.0            0.05             1.0       0       0
           283             0.0             0.1             1.0       0       0
           284             0.0            0.15             1.0       0       0
           285             0.0             0.2             1.0       0       0
           286             0.0            0.25             1.0       0       0
           287             0.0             0.3             1.0       0       0
           288             0.0            0.35             1.0       0       0
           289             0.0             0.4             1.0       0       0
           290             0.0            0.45             1.0       0       0
           291             0.0             0.5             1.0       0       0
           292             0.0            0.55             1.0       0       0
           293             0.0             0.6             1.0       0       0
           294             0.0            0.65             1.0       0       0
           295             0.0             0.0            1.05       0       0
           296             0.0            0.05            1.05       0       0
           297             0.0             0.1            1.05       0       0
           298             0.0            0.15            1.05       0       0
           299             0.0             0.2            1.05       0       0
           300             0.0            0.25            1.05       0       0
           301             0.0             0.3            1.05       0       0
           302             0.0            0.35            1.05       0       0
           303             0.0             0.4            1.05       0       0
           304             0.0            0.45            1.05       0       0
           305             0.0             0.5            1.05       0       0
           306             0.0            0.55            1.05       0       0
           307             0.0             0.6            1.05       0       0
           308             0.0            0.65            1.05       0       0
           309             0.0             0.0             1.1       0       0
           310             0.0            0.05             1.1       0       0
           311             0.0             0.1             1.1       0       0
           312             0.0            0.15             1.1       0       0
           313             0.0             0.2             1.1       0       0
           314             0.0            0.25             1.1       0       0
           315             0.0             0.3             1.1       0       0
           316             0.0            0.35             1.1       0       0
           317             0.0             0.4             1.1       0       0
           318             0.0            0.45             1.1       0       0
           319             0.0             0.5             1.1       0       0
           320             0.0            0.55             1.1       0       0
           321             0.0             0.6             1.1       0       0
           322             0.0            0.65             1.1       0       0
           323             0.0             0.0            1.15       0       0
           324             0.0            0.05            1.15       0       0
           325             0.0             0.1            1.15       0       0
           326             0.0            0.15            1.15       0       0
           327             0.0             0.2            1.15       0       0
           328             0.0            0.25            1.15       0       0
           329             0.0             0.3            1.15       0       0
           330             0.0            0.35            1.15       0       0
           331             0.0             0.4            1.15       0       0
           332             0.0            0.45            1.15       0       0
           333             0.0             0.5            1.15       0       0
           334             0.0            0.55            1.15       0       0
           335             0.0             0.6            1.15       0       0
           336             0.0            0.65            1.15       0       0
           337             0.0             0.0             1.2       0       0
           338             0.0            0.05             1.2       0       0
           339             0.0             0.1             1.2       0       0
           340             0.0            0.15             1.2       0       0
           341             0.0             0.2             1.2       0       0
           342             0.0            0.25             1.2       0       0
           343             0.0             0.3             1.2       0       0
           344             0.0            0.35             1.2       0       0
           345             0.0             0.4             1.2       0       0
           346             0.0            0.45             1.2       0       0
           347             0.0             0.5             1.2       0       0
           348             0.0            0.55             1.2       0       0
           349             0.0             0.6             1.2       0       0
           350             0.0            0.65             1.2       0       0
      *SET_NODE_LIST_TITLE
      Piston Motion
      $#     sid       da1       da2       da3       da4    solver       its         -
               1       0.0       0.0       0.0       0.0MECH      1
      $#    nid1      nid2      nid3      nid4      nid5      nid6      nid7      nid8
             246         0         0         0         0         0         0         0
      *SET_PART_LIST_TITLE
      ALE Mesh
      $#    pid1      pid2      pid3      pid4      pid5      pid6      pid7      pid8
               1         0         0         0         0         0         0         0
      *SET_MULTI-MATERIAL_GROUP_LIST_TITLE
      Water
      $#  ammsid
             102
      $# ammgid1   ammgid2   ammgid3   ammgid4   ammgid5   ammgid6   ammgid7   ammgid8
               1         0         0         0         0         0         0         0
      *END
    • Loic Ivaldi
      With a mpp R14.0 version I have a normal termination.
      Best Regards,
      Loïc
      • Caleb Wood
        Thank you for that Loic. I believe the issue is my solver (LS-RUN) is using version R10.
  • The topic ‘Error using ALE_STRUCTURED_FSI for S-ALE problem’ is closed to new replies.
