December 6, 2018 at 3:37 pm
Julia
SubscriberHello. I am running into an error when I try to open HFSS project files in ANSYS v19.0. I get this error with almost all of my files after opening/closing them several times so I am constantly losing results and projects. There seems to be no cause or pattern for this error as I change nothing with the project file or license for it to be corrupted. Clicking OK then opens the project but deletes my entire design in HFSS. I am running ANSYS v19.0 on a Windows 10 64bit installation on a Mac (bootcamp). Any help with this would be greatly appreciated!
December 8, 2018 at 4:29 pm
peteroznewman
SubscriberHello Julia,
You are on shaky ground running ANSYS on Windows 10 virtual machine on a Mac. It's not supported, so you may not get much help with this problem. Can you get access to an physical computer with Windows 10 installed naively? You will get more reliable operation, especially if the computer has a tested Graphics Card. You could then potentially use the Windows 10 on the Mac to do Windows Remote Desktop into that other computer that runs ANSYS.
If you can't follow the above advice and have to stay solely on the Mac, one idea is to always save files on the Windows C: drive. Make yourself a C:ansysdata folder and save your project there. I see you were saving on the Z: drive and that may be the problem.
After you have saved the project, you can also do File, Archive and create a .wbpz file. You can then copy that one archive file to the Z: drive for backup. You can do this if you are on a Remote Windows Desktop computer also.
Let me know if this suggestion makes any difference.
Peter -
December 9, 2018 at 3:37 pm
Julia
SubscriberHi Peter,
Thank you for the useful information! I do not have immediate access to a windows computer, but I did recently just set up a linux one (still with some issues as I posted about in this post - but that may be because the projects I was working on were edited on the virtual windows machine and stored/pulled from the shared Z: drive?)
Also, I use a cluster with Linux (red hat v7.4) to run large projects from the shared Z: drive. Is it safest to avoid that drive and/or windows altogether if I cannot get a physical windows machine?
Another option we have considered is partitioning a Mac for Linux. Would this be a better alternative than the windows partition?
Thanks,
Julia
- The topic ‘Error: Unable to open some designs in this project – Corrupted project files’ is closed to new replies.
- Basic questions about HPC license
- optiSLang: general question about output variables & expressions
- Keeping concentration same for different sized particles in discrete phase model
- 3-Way System Coupling (Thermal-Structural-Fluid)
- optiSLang & AEDT Optimetrics: response variable has value of 0
- Thermal Desktop: Running RadCAD and SINDA outside of AutoCAD
4683
1565
1386
1242
