March 25, 2021 at 3:19 pm
marcin.lelit
SubscriberI use recent version of Lumerical Suite on Windows. When running training simulation set up accordingly to FDTD100 tutorial video, simulation crashes at approx. 15%, with an error: "Process number 0 unable to locate checkpoint file." Can anyone point me to the solution of the problem? Log file attached.
March 25, 2021 at 11:32 pmLito
Ansys EmployeeArray, Is the simulation file saved in a location that you have write access? Try to save the simulation example into your user account/Downloads or Desktop folder.
Copy and paste the log results, we are unable to download files from ALF.
March 26, 2021 at 8:23 ammarcin.lelit
Subscriber.Dear Lito, thank you for taking interest in my question. I tried various directories, I have admin privileges. Interrupted simmulation generates movie file and log file in simulation file directory. Results are always the same, as described. Log results below and prtscr of job details:
Ansys Lumerical 2021 R1.2 FDTD Solver Version 8.25.2621 (Windows 64bit)
expires (month/day/year): Permanent
using config file: Ansys Licensing set with ANSYSLMD_LICENSE_FILE
license host: 1055@10.0.3.13
current time: Fri Mar 26 09:14:20 2021
Running on host: 49244_CEZ
host available memory (GB): 60.266922
All processes are communicating and ready to proceed to simulation...
Running fsp file: C:Program FilesLumericalv211infdtd-engine-msmpi.exe -t 1 -remote -resume C:/Users/m.lelit/Documents/Lumerical training/training simulation 1.fsp
This simulation has already been run, will run again.
The program terminated due to an error:Unable to locate any file matching 'C:Usersm.lelitDocumentsLumerical training raining simulation 1_*_p0.fsp.ckpt'
Error: Process number 0 unable to locate checkpoint file.
.March 29, 2021 at 9:04 pmLito
Ansys Employee.lelma87, try to disable checkpoint on the simulation.
Can you try and run the mwp.fsp file from this example? Does the issue happen to this example, mwp.fsp?
.March 30, 2021 at 9:42 ammarcin.lelit
SubscriberArray, thank ou for this suggestion. This worked but for some reason the other way around: at first, chceckpoint option was already disabled and error occured. However, when I checked both "checkpoint during simulation" and "checkpoint at schutoff", checkpoint files were generated and simmulation completed cuccessfuly.
mwp.fsp works fine regardless of checkpoint options - simmulation completed cuccessfuly with and without checkpoints.
March 30, 2021 at 10:06 pmLito
Ansys EmployeeArray, Glad to hear that this has been resolved.
May 19, 2021 at 4:20 amd08941008
Subscriber.Hi, I recently got the similar issue on the linux cluster with limited walltime of the queue. Is there any way to enable the checkpoint feature over terminal via fdtd-engine-impi-lcl command?
.May 19, 2021 at 8:29 pmLito
Ansys Employee.RyanChung
Starting a simulation job with checkpoint:
- Enable checkpoint in FDTD.
Run the simulation as you would without the -resume option.- This will create the checkpoint files based on the number of processes and checkpoint period.
- Ensure that the checkpoint files are created and not deleted when the simulation terminates.
To resume the simulation based on the last checkpoint:
- Do not change or edit the simulation.fsp file.
- Ensure that the checkpoint files are found together with your simulation.fsp file.
- Run the simulation with the -resume option. (do not use the "-resume" option if this is the first time you are running the simulation and you are not "resuming" a simulation job)
./fdtd-engine- -resume -fullinfo simulationfile.fspBest,
Lito
.May 23, 2021 at 7:19 pmd08941008
Subscriber.Thanks. I’ll enable it via CAD on the local PC before uploading it onto the CAD-free cluster.
.May 25, 2021 at 9:20 pmLito
You are welcome.
Best,
Lito
.July 19, 2023 at 12:39 pmqiu shi
Subscriberi also meet this problem,have you solved this problem?if you have solved it,i am very thankful if you can contact me,here is my eamil:asumirioyuzukarei@gmail.com
Viewing 10 reply threads- The topic ‘Error: “unable to locate checkpoint file” when running simple FDTD training simmulation’ is closed to new replies.
6680
1313
