November 24, 2020 at 2:34 pm
ecrod
SubscriberHello All,nI had a blue screen problem on my Windows 10. After that I cannot continue my simulations on Fluent.nI am always receiving a message --> Error: token too large Error Object: (), when I try to initialize a case or run it.nCould someone help me to solve it ?nThanks in advancen -
November 24, 2020 at 3:45 pm
Forum ModeratorIs that any case or just a specific one? n -
November 24, 2020 at 3:58 pm
ecrod
SubscriberHello Rob,nIt is happening for a specific case, that I was running when I received a blue screen error from Windows 10.n -
November 24, 2020 at 7:13 pm
DrAmine
Ansys EmployeeDetails about the case?n -
November 25, 2020 at 10:28 am
Forum ModeratorCan you open the case, and is it Fluent standalone or a Workbench project?n -
November 25, 2020 at 2:36 pm
November 25, 2020 at 3:21 pm
DrAmine
Ansys EmployeeYes Details like models, radiation, mesh count, etc.... n -
November 25, 2020 at 3:25 pm
DrAmine
Ansys EmployeeI have a feeling that this is mesh import issue. Can you load the mesh into Fluent Meshing?n -
November 26, 2020 at 2:55 pm
ecrod
SubscriberDrAmine,nI am not able to load my mesh in Fluent Meshing because it is a *.bdf file, and Fluent Meshing mode allows to load only *.nas file. nHowever, I successfully imported my mesh several times in Fluent and ran several cases. This issue is happening only after my windows problem. nI am able to load my case in Fluent solution mode, however I cannot start initialization process or even read previous data.n -
November 26, 2020 at 3:01 pm
DrAmine
Ansys EmployeeAfter loading that into Fluent are you able to check mesh?nWhat did happen with your Windows?n -
November 26, 2020 at 3:26 pm
ecrod
SubscriberYes. I am able to check the mesh and it is pretty fine as before the error message I received from Windows.nDuring simulation, my PC was reinitialized and I received a blue screen error message. After that, the case that was running before cannot run anymore. nI did all the process again, imported my mesh and setup my case, and it is fine. I really do not know what happened with the case after windows' error.nIt was a time consuming simulation, so unfortunately I will lost all and starting again.n -
November 26, 2020 at 4:34 pm
Forum ModeratorNot much help for now, but remember to use autosave and keep case & data. Also don't overwrite files if you can avoid it, it's safer to delete the extra files later. n -
November 26, 2020 at 7:53 pm
DrAmine
Ansys EmployeeAutosave is often neglected but is always recommended. Good ? n -
January 7, 2021 at 6:26 pm
ecrod
SubscriberI have used autosave. However, any datafile #almost 300) that I tried to load again failed.nn -
January 8, 2021 at 10:27 am
Forum ModeratorDid you save case and data? nWhat models are you using? Adaption and moving mesh mean you must save case and data at the same time as the mesh changes during the simulation. n
Viewing 14 reply threads
- The topic ‘Error: token too large’ is closed to new replies.
