April 5, 2020 at 8:29 pm
zed1234
SubscriberHello,
I am trying to find deflection of composite wing. I used ACP(PRE) and defined layers and etc.etc.
When I finally set the connections, supports and load.
I am getting this error:
the problem is that, when I check the mesh it has only 32536, so I can not even see, where the elements is.Â
Can you please help me how to solve this ? I am using 2019.R3 version.
Thank you very much
April 6, 2020 at 1:22 pm
Aniket
Forum ModeratorThere are extra elements defined for the contacts. Insert a contact tool in the tree and check for the real set 37. That should give you offending contact pair. Please check if the contact and target faces are correctly selected and oriented.
-Aniket
April 8, 2020 at 9:51 am
April 8, 2020 at 10:27 am
zed1234
SubscriberI cannot even generate the initical condition in Contact Tool it just does not show any results.
April 9, 2020 at 10:45 am
Aniket
Forum ModeratorWhat error do you get when evaluating the contact tool? Try with Distributed turned off and see if that helps.
if not, delete the contact tool from the tree and insert a new one and retry.
Once you generate the initial results you can sort them by real constant, and then right-click on that row and go to the concerned contact in the tree:
- The topic ‘*ERROR* Tne normal of target element’ is closed to new replies.
3467
1057
1051
929
896
