error: the value of UX node exceeds , , any solution ?
    • moeenkhurram
      I already command  tried ncnv, ,le30 , still getting this error.
    • jj77
      Could be a rigid body mode - run a modal analysis to see that everything is connected as it should be
  • The topic ‘error: the value of UX node exceeds , , any solution ?’ is closed to new replies.
