Error: The UDF library you are trying to load is not compiled for 3d on the current platform (win64)
January 15, 2019 at 4:02 pm
kadimtalebe
SubscriberHello,
I cant compile my udf . I have ANSYS Release 18.0. I looked other posts but still I have same problem.
/forum/forums/topic/problems-loading-udf-for-moving-mesh-in-fluent/
according to this post, I installed Visual Studio Community 2015 and SDK. But nothing changed.
Do you have any suggestions?
January 15, 2019 at 6:24 pm
Amine Ben Hadj Ali
Ansys EmployeeSDK is not really required here. Just open x86_46 Cross Tool Command Prompt from VS Program launch Fluent from there, try to compile.Â
January 15, 2019 at 7:28 pm
kadimtalebe
SubscriberI tried that but Still I have same problem.
January 15, 2019 at 8:10 pm
Amine Ben Hadj Ali
Ansys EmployeeMake a clean uninstall of all VS releases and SDK. Install VS once again as admin and try again. I
January 16, 2019 at 12:59 pm
January 16, 2019 at 3:17 pm
kadimtalebe
SubscriberI solved the problem.I applied this:
"Set the correct environment variables. Browse your way through the Windows system control to 'System'. There you will find a section 'Advanced system settings'. In the following dialog go to the 'Advanced' tabulator and click on 'Environment variables' (lower right corner). Go through the 'System variables' list and search for the 'Path' entry. Add the following to the variable:Â C:Program Files (x86)Microsoft Visual Studio 10.0Common7Tools;C:Program Files (x86)Microsoft Visual Studio 10.0VCbin;C:Program FilesANSYS Incv120fluentntbinwin64"
In my system it is like this:Â C:Program Files (x86)Microsoft Visual Studio 14.0Common7Tools;C:Program Files (x86)Microsoft Visual Studio 14.0VCbin;C:Program FilesANSYS Incv180fluentntbinwin64
Then, problem is solved.
April 21, 2020 at 11:18 am
Martita
SubscriberHi!
I have the same problem, did you create a new variable or did you edit one of the existing variables??
April 21, 2020 at 11:26 am
kadimtalebe
SubscriberHi Martita!,
I am not sure but as far as I remember, I found the path from system variables then I added a new variable.
April 21, 2020 at 11:30 am
Martita
SubscriberWith a random name?
April 21, 2020 at 11:34 am
April 21, 2020 at 5:03 pm
October 30, 2020 at 3:53 pm
attiq
SubscriberI am facing this error (statement below) How to get it off?nError: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64).The system cannot find the file specified.nC:\Users\HP 15 BS\Desktop\Dynamic Mesh Practice_files\dp0\FFF\Fluent\libudf\win64\2ddp_host\libudf.dllnError Object: #fn -
January 21, 2021 at 3:24 am
Hesam062
SubscriberHinI also have the sane problem. I tried to use your solution but my visual studio (2017) does not include any folder named VC (for second path that you said should be past in variable). Do you know what is wrong by chance?n -
January 21, 2021 at 9:29 am
Amine Ben Hadj Ali
Ansys EmployeeUpdate to at least release 2020R2 and use the built in compiler in Fluent.n
- The topic ‘Error: The UDF library you are trying to load is not compiled for 3d on the current platform (win64)’ is closed to new replies.
5069
1770
1387
1248
