October 27, 2021 at 2:59 pm
elisio
SubscriberHi,
i want to evaluate the velocity variation inside a heat exchanger with a simple 2D model, but while while meshing i get this error: The Quad Mesher failed on one or more faces. I can't figure it out what it exactly means, but I have read some edge size applications to solve it. It didn't work for me. This is half model:
October 28, 2021 at 11:21 amRob
Forum ModeratorHow much space is there between the tubes?
October 28, 2021 at 3:38 pmOctober 28, 2021 at 3:57 pmRob
Forum ModeratorWhat shape of quad element do you expect to be created? Feel free to sketch on paper and report back.
October 28, 2021 at 4:17 pmelisio
Subscriberi have created really small elements and it still wasn't possible. So a simple change to tetrahedral solved it.
Thanks Rob.
October 28, 2021 at 4:36 pmRob
Forum ModeratorIt won't be, and I suspect the skew on the tri elements is fairly high. In CFD terms I'd tend to expand the contact region a little bit to remove the tangential intercept: I'm a little surprised the CAD worked too as that's a "non manifold body" and tends to cause problems.
Viewing 5 reply threads- The topic ‘[ERROR] The Quad Mesher failed on one or more faces.’ is closed to new replies.
5934
1307
