June 21, 2023 at 2:40 am
Gary Wang
SubscriberHi, in the model I meshed below, I got an error reading that (The normal of contact element 7869 is not consistent with the normal of contact element 7888 in real set 39. Please use the ENORM command to correct it.). I have checked some results in the forum, while haven't solved it. I have checked the normals of my connections, the contact face did show an abnormal mesh normal which is different from others with arrow down. The contact here is simple with just a plane (solid) and a ball (shell). The mesh I used for the contact is MultiZone shown below. The whole mesh didn't see any error, while the solving can't proceed.
I have checked some resources, e.g. ENORM the element below. while it gives me that (Element number 0 is not defined as part of the current model.) Can someone help me with this error? Thanks a lot.
Ref:
/forum/forums/topic/normal-tangent-element-not-consistent-error/
https://www.eng-tips.com/viewthread.cfm?qid=381557
http://muchong.com/t-7294231-1
June 21, 2023 at 2:43 am
June 21, 2023 at 3:46 pm
Akshay Maniyar
Ansys EmployeeHi Gary,
Please check the below knowledge material on the error message. It might help you to resolve the issue.
Thank you,
Akshay Maniyar
June 25, 2023 at 2:25 am
Gary Wang
SubscriberHi Akshay,
Thanks for your sharing. I have solved this similarly to the solutions mentioned in your provided link. I added a Contact Sizing mesh to the failing contact, the mesh was refined and the normal are all the same now.Â
A follow-up question is, how to use ANORM in APDL?Â
Thanks a again.
June 26, 2023 at 7:18 am
Akshay Maniyar
It is great that your issue is resolved. Can you mark this thread as resolved and start a new thread for the follow-up question? So that other users with similar issue can search for it easily.
Thank you,
Akshay Maniyar
- The topic ‘[Error] The normal of contact element is not consistent’ is closed to new replies.
5649
1885
1403
1303
