May 8, 2019 at 3:23 pm
LucaB
SubscriberHi, I exactly followed the tutorial about rectangular waveguide linked below, but when I click on "Analyse All" button I get these messages and the analysis is stopped.
[info] A discrete frequency sweep with 122 point(s) has been started using HFSS - Solving Distributed. (4:17:25 PM May 08, 2019)
[error] The HFSS solver failed to start. Please contact technical support. (4:17:25 PM May 08, 2019)
[error] Simulation completed with execution error on server: Local Machine. (4:17:25 PM May 08, 2019)
Do you know what could be the reason?
 https://www.youtube.com/watch?v=F6qOlGe1wrw
May 20, 2019 at 7:54 pm
Sorceress Gia
Ansys EmployeeIf the main solution solves, but the discrete frequency sweep fails then you may not have the license required to do a 'distributed solve' - where multiple frequencies are solved in parallel. -Â Go to the HPC settings, uncheck 'Auto-HPC', and make sure only 1 task is set. - Then re-run the frequency sweep. - It is also probably unnecessary (and will take a much longer time) to do a discrete sweep - choose interpolated sweep instead...
May 21, 2019 at 10:19 am
LucaB
SubscriberThank you, it works now
- The topic ‘Error: The HFSS solver failed to start. Please contact technical support’ is closed to new replies.
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- AEDT Natural Convection with default correlation is failing solver initializatio
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
3862
1414
1220
1118
1015
