Error: Surface Creation Failed!
    • mjluzipho
      Hello, I'm trying to create a lines in Fluent (one is on the inlet line in blue) but I keep getting the error message seen the attached image. Please kindly advise on how I can progress from here. I tried changing the units from m to cm like someone mentioned in a previous forum post but to no avail.
    • Federico
      I would suggest checking the domain and make sure that this line intersects it. In Fluent, go to Domain > Mesh > Scale... and see if this line is within range.
      • mjluzipho
        Thank you for response, Federico.
  • The topic ‘Error: Surface Creation Failed!’ is closed to new replies.
