May 15, 2019 at 5:27 am
madhavair19
SubscriberHello,
I want to create a line in Fluent so that I can get my results in that particular line. While doing that, I get an error saying that:
Error: Surface creation failed !
Error object: #f
Can someone help me on how to resolve this ?
P.S: The end points of my line is within the flow domain and it is a 2D model. Interestingly, when I created a line with the default values in the dialog box, the line was created.
Thank you !
October 5, 2019 at 10:32 pm
reza1reza
Subscriber -
October 7, 2019 at 3:28 pm
Forum ModeratorFluent always works in SI units and converts internally from any other units you set. I suspect the Quadratic surface panel hasn't been checked as it's rarely used: I'll flag to the GUI team to check.Â
- The topic ‘Error: Surface Creation Failed’ is closed to new replies.
1830
1387
1248
