April 8, 2026 at 1:49 pm
marshal.andreas.pub
Subscriber The problem is I can do Static Structural on its own, but i don't know why it just can't when i Imported Temperature from Steady State Thermal. Help me guysÂ
the error message is follwong guys:*** ERROR ***Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â CP =Â Â Â 8227.219Â Â TIME= 20:39:50
 The value of UY at node 479015 is 423481388. It is greater than the  Â
 current limit of 1000000 (which can be reset on the NCNV command).    Â
 This generally indicates rigid body motion as a result of an          Â
 unconstrained model. Verify that your model is properly constrained. Â
 *** ERROR ***                          CP =   8227.219  TIME= 20:39:50
 *** MESSAGE CONTINUATION ---- DIAGNOSTIC INFORMATION ***              Â
 If one or more parts of the model are held together only by contact   Â
 verify that the contact surfaces are closed. Also make sure that     Â
 there are constraints (or friction) in the sliding direction even if  Â
 no load is applied in that direction. You can use the CNCHECK commandÂ
 to check the initial contact status in the SOLUTION module.       4
Static Structural
April 8, 2026 at 6:40 pm
peteroznewman
SubscriberPart of your structure is not connected in the Y direction. One diagnostic check to find the unconstrained part is to drop a Modal analysis on the Static Structural Model cell. In Mechanical, drag the Fixed Support from the Static Structural branch and drop it on the Modal branch. Under Analysis Settings for Modal, request 12 modes instead of 6. Solve the Modal and plot Deformations for all modes. I expect you will see the frequency for mode 1 is nearly zero. In the Details window for Deformation plot of mode one is the name of the part with the maximum deformation. You may see it float around in the animation of the Deformation for mode 1. That is the part you have to constrain.
April 9, 2026 at 1:08 am
marshal.andreas.pub
SubscriberI performed the modal analysis, yet it just cant get the result:
 *** WARNING ***             CP =   114.297  TIME= 07:48:18 The PCG Lanczos eigensolver has detected that the matrix used during  Â the PCG iterations is indefinite. This will likely result in an    Â increased number of iterations required to reach convergence as well  Â as longer solution times. It is recommended to switch to another   Â Lev_Diff value on the PCGOPT command (e.g., Lev_Diff = 5) or switch to Â another eigensolver, such as Block Lanczos (MODOPT,LANB).       Â                                    Â *** WARNING ***             CP =  8573.484  TIME= 07:59:33 The PCG solver detects that the out of balance force goes to      Â infinity.The solution has not converged. Please check for rigid body Â motions in your model.                         Â                                    Â *** ERROR ***              CP =  8573.500  TIME= 07:59:33 The PCG Lanczos eigensolver has failed to converge while solving the  Â linear system of equations for the current Lanczos iteration. Please Â switch to the Block Lanczos eigensolver (MODOPT,LANB) in order to   Â extract the mode shapes for this model.                Â                      Â
April 9, 2026 at 1:45 am
peteroznewman
SubscriberUnder Analysis Settings, change the Solver to Direct.
April 9, 2026 at 3:08 am
marshal.andreas.pub
Subscribernope, doesnt work
 the messages as following: *** ERROR ***              CP =   609.781  TIME= 09:07:17 Size too large for a memory allocation.                Â *** ERROR ***              CP =   609.781  TIME= 09:07:17 Failure in BLOCK LANCZOS eigensolver. Error code = -1. Please send  Â the data leading to this operation to your technical support provider, Â as this will allow ANSYS, Inc to improve the program.         Â *** WARNING ***             CP =   609.781  TIME= 09:07:17 Fewer modes than the requested number of modes ( 12 ) were computed.  Â There are only 0 modes beyond the begin frequency of FREQB= 0.     Â NUMBER OF WARNING MESSAGES ENCOUNTERED=    176 NUMBER OF ERROR  MESSAGES ENCOUNTERED=     2Â
April 9, 2026 at 3:29 am
marshal.andreas.pub
Subscriberfyi, i do still use automatic connection and it works when i do steady state thermal analysis
April 9, 2026 at 3:33 am
April 9, 2026 at 3:43 am
April 9, 2026 at 11:13 am
peteroznewman
SubscriberThe small text in the screen snapshots is nearly illegible. The software you are using to take them is reducing the screen image resolution. Windows comes with Snipping Tool which does not reduce screen resolution at all. Try using that to paste images into your replies.
If that last image is for Mode 1, the frequency is now non-zero which is required for Static Structural to solve without an error. When you animate that result, does the part with the Maximum deformation move in a way that shows it is connected to other parts in a sensible manner? What do you mean by "with contact on"?
In the second last image, the frequency is zero so that would mean Static Structural will give an error. The corrective action is to attach that part to whatever that part is supposed to be attached to. A part that floats that is meant to be fixed to ground should have a Fixed Support but if the part that floats is meant to be attached to other parts, then you need Bonded Contact to connect it to other parts so it doesnt float.
April 9, 2026 at 1:00 pm
marshal.andreas.pub
SubscriberHere is the modal analysis
I don't use shared topology due to easier hexahedral meshing and I use automatic contacts (it works wonder for my steady state thermal)
As u can see, there is no floating part and the part that have maximum deformation still moves in sensible manner
The problem is when i only import the load temperature on static structural, but when i leave the static structural with gravity only, it works.png)
April 9, 2026 at 3:38 pm
peteroznewman
SubscriberNow that you have a Static Structural model that solves with a gravity load only, show that deformation result.
When you add an Imported Temperature load you get an error, show that error, plot the Imported Load temperature and the Details window.
Under Analysis Settings, try turning on Large Deflection, does that change the error?
What is the Coefficient of Thermal Expansion value for each material used?
April 9, 2026 at 4:43 pm
marshal.andreas.pub
SubscriberNo Large Deflection: *** NOTE ***              CP =  4225.578  TIME= 23:11:31 The Sparse Matrix Solver is currently running in the in-core memory  Â mode. This memory mode uses the most amount of memory in order to   Â avoid using the hard drive as much as possible, which most often    Â results in the fastest solution time. This mode is recommended if   Â enough physical memory is present to accommodate all of the solver   Â data.                                 Â Sparse solver maximum pivot= 2.911567527E+21 at node 129856 UY.    Â Sparse solver minimum pivot= -1.831809152E+21 at node 126907 UY.    Â Sparse solver minimum pivot in absolute value= 2485.20108 at node   Â 231642 UY.                               Â *** ERROR ***              CP =  4297.906  TIME= 23:12:05 The value of UY at node 238523 is 287245902. It is greater than the  Â current limit of 1000000 (which can be reset on the NCNV command).   Â This generally indicates rigid body motion as a result of an      Â unconstrained model. Verify that your model is properly constrained. Â *** ERROR ***              CP =  4297.906  TIME= 23:12:05 *** MESSAGE CONTINUATION ---- DIAGNOSTIC INFORMATION ***        Â If one or more parts of the model are held together only by contact  Â verify that the contact surfaces are closed. Also make sure that   Â there are constraints (or friction) in the sliding direction even if  Â no load is applied in that direction. You can use the CNCHECK command ÂAfter Large Deflection: *** NOTE ***              CP =  4196.156  TIME= 23:34:03 The Sparse Matrix Solver is currently running in the in-core memory  Â mode. This memory mode uses the most amount of memory in order to   Â avoid using the hard drive as much as possible, which most often    Â results in the fastest solution time. This mode is recommended if   Â enough physical memory is present to accommodate all of the solver   Â data.                                 Â Sparse solver maximum pivot= 6.877451288E+21 at node 129856 UX.    Â Sparse solver minimum pivot= -2.370368105E+20 at node 243904 UZ.    Â Sparse solver minimum pivot in absolute value= 5926.59524 at node   Â 231167 UY.                               Â *** ERROR ***              CP =  4268.984  TIME= 23:34:39 The value of UY at node 238523 is 287184481. It is greater than the  Â current limit of 1000000 (which can be reset on the NCNV command).   Â This generally indicates rigid body motion as a result of an      Â unconstrained model. Verify that your model is properly constrained. Â *** ERROR ***              CP =  4268.984  TIME= 23:34:39 *** MESSAGE CONTINUATION ---- DIAGNOSTIC INFORMATION ***        Â If one or more parts of the model are held together only by contact  Â verify that the contact surfaces are closed. Also make sure that   Â there are constraints (or friction) in the sliding direction even if  Â no load is applied in that direction. You can use the CNCHECK command Â to check the initial contact status in the SOLUTION module. Â
5984
1307
