September 13, 2020 at 11:18 am
ABilal
Subscriberany help please !
September 13, 2020 at 12:59 pmANSYS_MMadore
Forum ModeratorPlease try setting the environment variable ANSYS_EM_DONOT_PRELOAD_3DDRIVER_DLL=1 to get around the problem.nThanks,nMattnSeptember 13, 2020 at 7:57 pmABilal
Subscriberthank you for reply .nWhere is it the variable ANSYS_EM_DONOT_PRELOAD_3DDRIVER_DLL=1 Â nnSeptember 13, 2020 at 8:02 pmANSYS_MMadore
Forum ModeratorYou need to set a new variable as detailed in this link.nhttps://www.computerhope.com/issues/ch000549.htmnSeptember 13, 2020 at 8:36 pmSeptember 13, 2020 at 9:44 pmANSYS_MMadore
Forum ModeratorYou don't add it to the Path variable. You click New to create a new variable. The variable name will be ANSYS_EM_DONOT_PRELOAD_3DDRIVER_DLL and the Value will be 1.September 13, 2020 at 11:23 pmABilal
SubscriberCould you help me with this? Thank you very much.nn A window pops and says,nnFailed to check out license 'hfss_desktop'.nCannot connect to license server (FLEXlm Error -15)nnFailed to check out license 'designer_desktop'.nCannot connect to license server (FLEXlm Error -15)nnFailed to check out license 'q3d_desktop'.nCannot connect to license server (FLEXlm Error -15)nnFailed to check out license 'maxwell_desktop'.nCannot connect to license server (FLEXlm Error -15)nnFailed to check out license 'simplorer_desktop'.nCannot connect to license server (FLEXlm Error -15)nnFailed to check out license 'electronics_desktop'.nCannot connect to license server (FLEXlm Error -15)nnSeptember 14, 2020 at 11:17 amABilal
Subscriberit resolvednnthanks nSeptember 15, 2020 at 7:56 amjrahul5290
SubscriberI was facing same problem. Followed the recommended steps and it resolved. Thank you So much Sir. nDecember 12, 2020 at 11:08 amLax
SubscriberHi mmadore ,nI am also getting same error.. while running my ANSYS app. I have made the changes as said here to make...nANSYS_EM_DONOT_PRELOAD_3DDRIVER_DLL and the Value will be 1.nnPlease helpnDecember 12, 2020 at 11:11 amLax
SubscriberError are as here:nFailed to check out license 'hfss_desktop'.nInvalid license file syntax (FLEXlm Error -2)nnFailed to check out license 'designer_desktop'.nInvalid license file syntax (FLEXlm Error -2)nnFailed to check out license 'q3d_desktop'.nInvalid license file syntax (FLEXlm Error -2)nnFailed to check out license 'maxwell_desktop'.nInvalid license file syntax (FLEXlm Error -2)nnFailed to check out license 'simplorer_desktop'.nInvalid license file syntax (FLEXlm Error -2)nnFailed to check out license 'electronics_desktop'.nInvalid license file syntax (FLEXlm Error -2)December 14, 2020 at 1:23 pmANSYS_MMadore
Forum Moderatorcan you please share a copy of your license file? This error is unrelated to the previous comments in this thread. This message is telling me the license is invalid.nnThanksnMattnFebruary 3, 2021 at 5:16 pmFebruary 4, 2021 at 1:22 pmANSYS_MMadore
Forum ModeratorArrayCan you open a Windows command prompt and run the command set without the quotes and share the full output?.Thanks,nMattnFebruary 17, 2021 at 7:42 pmabhishek120
SubscriberThanks, it worked after I restored my PC without the updates.nMarch 5, 2021 at 5:12 pmViewing 15 reply threads- The topic ‘ERROR : [reg ansysedt exe] AnsysEM19.2’ is closed to new replies.
5069
1771
1387
1248
