October 4, 2017 at 12:20 pm
pgl
Ansys EmployeeWhat is the cause of error: Radiation element has negative or zero temperature?
October 17, 2017 at 9:51 am
Arun Kumar
Ansys EmployeeDefine the substeps for proper radiation calculation otherwise you may get negative values. Also, specify an initial temperature for the model around the expected temperature so the solution starts farther from zero. Make sure an offset temperature has been defined (TOFFST).
- The topic ‘Error: Radiation element has negative or zero temperature’ is closed to new replies.
1859
1387
1255
