TAGGED: -Structured-Meshing, conformal, low-memory, meshing
August 6, 2024 at 6:43 pm
Xbuddyin
SubscriberDear friends,
I'm encountering an "out of memory" error while attempting to simulate the cavitation effect alongside a turbulent model. Previously, I successfully simulated basic flow profiles with the same mesh density. However, adding cavitation has caused the simulation to fail due to memory constraints. I've attempted a hybrid initialization method after standard initialization failed to complete.
Given these challenges, should I consider increasing RAM capacity as a solution? Any suggestions or alternative approaches to optimize memory usage would be greatly appreciated.
Thank you for your assistance.
August 7, 2024 at 8:39 am
Forum ModeratorHow many cells have you got, and how much RAM. Are you running PBCS? Which multiphase model are you using?
6179
