October 2, 2024 at 1:00 pm
October 2, 2024 at 1:43 pm
Forum ModeratorGo into the folder listed in the path using File Explorer, and see what's there. Copy the contents somewhere safe and then see what can be opened. Also check disc space and access. Unless you're doing anything linked to parameters it's generally recommended to use Fluent in stand alone mode.Â
October 2, 2024 at 3:55 pm
scabo
SubscriberHi
All the directories listed inside have nothing in there, they are all empty folders. My disk space is slightly low and has around 22 GB of free space. I cant identify whats going wrong.
October 2, 2024 at 4:29 pm
Forum ModeratorIs there a scratch folder? Hopefully the files are also in there.Â
October 2, 2024 at 8:17 pm
scabo
SubscriberHi
There is no scratch folder in the files. But there is a project_cache folder.
Viewing 4 reply threads
1890
1419
1304
