March 15, 2019 at 11:08 pm
colintho
SubscriberHello,
I was discussing yesterday about an issue modelling airflow around a ribbed plate, I resolved this and managed to get the model to work.
However I am now trying to model this ribbed plate inside a larger fluid volume but when I try subtract the plate (material) from the fluid volume frozen) it fails.
Can anyone try do this or advise how to do this as I can't see what is stopping it image shown below!
March 18, 2019 at 9:54 am
Forum ModeratorBoolean operations are designed to work with volume parts: if the baffles etc are surfaces it'll fail. Can you show some more detail of the problem area? You may be better off creating volume regions between the fins and then doing a split or subtract+retain to give you the features & then label the baffles as "wall-something" in Meshing.Â
March 19, 2019 at 3:42 am
Keyur Kanade
Ansys Employeehttps://www.youtube.com/watch?v=3OY_hsGxoQ8
- The topic ‘Error on boolean subtraction’ is closed to new replies.
4683
1565
1386
1242
