Error occurred – data did not mark container as updated (final state is Modified)
    • Aaron_123456
      The above error message occurred relating to engineering data component whilst running mesh convergence study using parameters. nIt appeared to be the result of a single design point, I have since removed all parameters from 15 systems and the error remains. nThe individual systems solve for user input mesh parameters ie; edge length, but fail to solve using the parameter/ design point screen.nnThanks in advance
    • Gary_S
      The message is generic in that the object failed to mesh or failed to solve etc.nIt may be that the project is corrupt in some way.nOpen Mechanical, then File - Export - .mechdat. nStart a New WB projectnDrag the .mechdat onto the project whitespace.nEnter your Design Points etc. nSave and try the solve again.
  • The topic ‘Error occurred – data did not mark container as updated (final state is Modified)’ is closed to new replies.
