September 21, 2023 at 9:06 am
September 21, 2023 at 9:50 am
ErKo
Ansys EmployeeHi
It is hard to know what this means (it is a generic solver error message that does not say why it crashed).
Does the model run if you simulate less time (thus shorten the end time and how long the simulation lasts) so make it only a few 1000 cycles perhaps and see if it works.
All the best
Erik
September 21, 2023 at 10:52 am
ahmed.taher
Subscriberthis is my first time running a model this big, all models I ran before were having maximum of 50000 cycles. So, I don't know in fact if this is normal or not
The reason I am making this model is that, I am trying to apply an axial load to calculate residual stress after a blast stage, the problem is the "stain rate" effect, I need to apply the axial load gradually. in autodyn, the time scale is too small (ms) in which axial load won't tell the true value of stress if it was loaded gradually. So i ran a model this big but it shows the error. the thing is, if I opened a pre saved cycles from the same model, it now shows the error message
So, What can I do? Is there a way to solve this issue? If not, then is there a way to avoid the strain rate effect while applying the axial load?
Thanks,
- The topic ‘Error message in autodyn’ is closed to new replies.
5179
1836
1387
1249
