March 26, 2024 at 1:08 pm
jmoss
SubscriberHello,
I received the following error message when attempting to solve the turbulent component during a flow analysis in Fluent.
The laminar component solved without issue. Is this error message a result of Fluent setup or is it the result of computer related issue ( ex: corrupted workbench file, etc.)
Thanks in advance,
April 2, 2024 at 5:42 pm
Federico
Ansys EmployeeHello Jason,
it is difficult to say from this information alone. The error just says that the solution for the system called “Turbulent” failed.
Can you provide more details on the changes that you made from your Laminar setup to the Turbulent setup which may have caused this?
April 2, 2024 at 6:24 pm
jmoss
Subscriberthanks for the response. turns out that the component was indeed corrupted and was successful after creating a new workbench file.
April 3, 2024 at 11:43 am
Federico
Ansys EmployeeGood to know that you resolved the issue!
- The topic ‘error message for Turbulent solution component in Fluent’ is closed to new replies.
5934
1306
