August 7, 2019 at 9:16 pm
Aslinn
SubscriberHi all, I got the error message as following in the solver. Could someone please help me to resolve this issue?
"The orientation node of element 32973 is co-linear with the first two nodes."
Thank you very much!
August 7, 2019 at 11:43 pm
peteroznewman
SubscriberI'm guessing that you have a beam model, because beam elements have orientation nodes.
Linear beam elements have two nodes to define the line that the beam runs along.
Beam elements have a cross-section that has to be oriented around the beam.
An orientation node does that, but it can't if that node lies on the line between the other two nodes. Move it off the line.
- The topic ‘Error message: Element orientation’ is closed to new replies.
1587
1386
1242
