Error: malformed pair: too many objects in CDR
    • AdeKPutra
      Hello everyone,
      I have this Error:
      Error Object: (25 . "contact_region_10-contact_region_12-contact_region_9-contact_region_12-contact_region_40-contact_region_46-contact_region_47-contact_region_19-contact_region_43-contact_region_46-contact_region_48-contact_region_16-contact_region_17-contact_region_19-cold_Ä") (26 . ")
    • Amine Ben Hadj Ali
      When are you getting the error?
    • AdeKPutra
      Dear Mr abenhadj
      I got that error while building mesh in set up solution. that message appear and stoping to build mesh
      Best Regard
      AKPutra
      There is A with umlaut in one contact name? Is this true?
    • AdeKPutra
      FYI my inner pipe design in the outside surface using helical fins.
      yes, you're right sir. there is A with umlaut. that's true
      Best regards,
      AKPutra
      Try without umlaut.
    • AdeKPutra
       umlaut appear when building mesh in setup solution
      mesh process stopped, ant then in console appeared this message
      If you open Meshing, how many contact pairs/surfaces have you got?  Are they all valid: ie should they all be there?
    • AdeKPutra
      49 and they are all valid
      Do you need them all? Ie can you create a conformal mesh?
Viewing 9 reply threads
  • The topic ‘Error: malformed pair: too many objects in CDR’ is closed to new replies.
