November 15, 2018 at 6:41 pm
Abkhan274
SubscriberHello guys,
I am new with Ansys. I created a geometry of a rectangular hollow steel section with solid 185 element. When I apply the mesh command, there appears a topology error. I've been trying to solve this error for quite a while but in vain. What I've understood is that there is some kind of problem in attributing element but I can't figure it out. It would be a big help if someone can review the code
November 16, 2018 at 9:37 am
Aniket
Forum ModeratorANSYS employees cannot download any attachments on a public forum. So can you please post the code inline along with inline images?
Also, from the description, it seems like you are using APDL to create and mesh this model. These things are comparatively easy for a new user inside workbench Mechanical. Is there any specific reason that you are not using Workbench and using APDL?
November 18, 2018 at 10:20 am
Abkhan274
SubscriberYes I am using APDL. I am working on my master thesis and my supervisor asked me to use it.
finish
/clear,start
*afun,deg
/UNITS,SI
!chord parameters
B=0.280
H=0.280
T=0.020
Len=2.80
!brace parameters
bo=0.140
ho=0.140
to=0.020
lob=0.70 !length of brace
lo=1.47 !location of brace from chord origin
linc=1.26 !location of 2nd brace from chord origin
EM=210000
PR=0.3
force=2000
/prep7
!keypoints for chord
k,1,0,0,0
k,2,B,0,0
k,3,B,H,0
k,4,0,H,0
!Keypoints at middle of outer rec.
k,5,0,H/2,0
k,6,B/2,0,0
k,7,B,H/2,0
k,8,B/2,H,0
!Keypoints at middle of inner rect.
k,9,B/2,H-T,0
k,10,T,H/2,0
k,11,B/2,T,0
k,12,B-T,H/2,0
!Keypoints for brace
!Outer sec.
k,21,0.070,H+lob,lo
k,22,0.210,H+lob,lo
k,23,0.210,H+lob,lo-0.140
k,24,0.070,H+lob,lo-0.140
k,25,0.070,H+lob,lo-0.070
k,26,0.140,H+lob,lo
k,27,0.210,H+lob,lo-0.070
k,28,0.140,H+lob,lo-0.140
!inner rec.
k,29,0.090,H+lob,lo-0.020
k,30,0.190,H+lob,lo-0.020
k,31,0.190,H+lob,lo-0.1-0.02
k,32,0.090,H+lob,lo-0.1-0.02
!keypoints for 2nd brace (outer sec. on chord end)
k,33,0.070,H,linc
k,34,0.21,H,linc
k,35,0.21,H,linc-0.2178 !(1.54+0.2178)
k,36,0.070,H,linc-0.2178
!(inner sec. on chord end)
k,37,0.090,H,1.24
k,38,0.190,H,1.24
k,39,0.190,H,1.0622
k,40,0.090,H,1.0622
!(outer sec. on free end)
k,41,0.07,H+0.4499,0.724
k,42,0.21,H+0.4499,0.724
k,43,0.21,H+0.3427,0.63401
k,44,0.07,H+0.3427,0.63401
!(inner sec. on free end)
k,45,0.090,H+0.4345,0.7111
k,46,0.190,H+0.4345,0.7111
k,47,0.190,H+0.3580,0.6468
k,48,0.090,H+0.3580,0.6468
l,5,10
l,6,11
l,7,12
l,8,9
allsel,all
!Chord cross section
rectng,0,B,0,H
rectng,T,B-T,T,H-T
asba,1,2,,delete,delete
allsel,all
vext,all,,,0,0,Len
!Brace cross section
a,21,22,23,24
a,29,30,31,32
asel,all
asba,11,12,,delete,delete
asel,all
aglue,all
allsel,all
!Extruding brace area by offset
voffst,13,-lob
!2nd brace area
a,33,34,35,36 !outer sec
a,37,38,39,40 !inner sec
!2nd brace x-area at free end
!area
a,41,42,43,44
a,45,46,47,48
asba,21,22,,delete,delete
asel,all
btol,0.10e-1 !increasing the tolerance level so that the points within increased distanced are assumed to be coincident
asba,23,24,,delete,delete
asel,all
!Creating volume for incline brace by selecting keypoints of already defined area
v,37,38,39,40,45,46,47,48
v,33,34,35,36,41,42,43,44
vovlap,3,4
vdele,3
allsel,all
adele,28
!vglue,all
!aglue,all
et,1,185
mp,ex,1,EM ! Definiere E-Modul
mp,prxy,1,PR
!esize,0.5
mat,1
type,1
mshape,0
mshkey,1
vmesh,all
!Boundary conditions (inclined brace free end)
!local,11,0,0,0.72990,0.7240,0,40,0,1,1
!allsel,all
!ksel,s,loc,z,0 !2nd brace (inclined)
!ksel,r,loc,y,0,0.140
!ksel,r,loc,x,0,0.140
!dk,all,uz,0
!ksel,all -
November 18, 2018 at 10:27 am
August 10, 2021 at 6:55 am
seeker
Subscriber.HI Sir , I am also facing the same problem. how can I fix it
- The topic ‘Error: Invalid topology for mapped brick meshing’ is closed to new replies.
3572
1193
1076
1063
952
