TAGGED: dpm, dpm-boundary-condition, dpm-concentration, dpm-tracking, spray
November 26, 2024 at 4:34 am
me22d077
SubscriberWhile working on a simulation, I observed that certain input parameters, such as flow rate and velocity, are not being reflected in the simulation results as expected.
For example if I am giving flow rate as 0.00382kg/sec for 0.61mm diameter of nozzle I am not getting the velocity as 13.11m/s.I was using full solid cone angle.Â
November 26, 2024 at 11:32 am
Forum ModeratorIf you're setting a cone angle that implies a particle injection, but you're displaying fluid velocity vectors. If that's the case, why would the fluid reach the injection speed?Â
November 27, 2024 at 6:55 am
me22d077
SubscriberI was trying to validate a paper, they have used same cone angle and they also shown the velocity vectors. But they obtained the velocity correctly if we calculate using continuity equation. So Can you please explain it further how to obtaint the velocity,as I kept same flow rate and diameter to obtain same velocity?
December 10, 2024 at 11:09 am
Prashanth
Ansys EmployeeHello Viraj,
Can you please help us understand the issue better? I understand you have a DPM injection setup. Have you tried post-processing particle velocity vectors and see if it matches, maybe the paper you mentioned does that..
December 19, 2024 at 9:00 am
me22d077
SubscriberOkay. How to see particle velocity vectors in CFD post process? It is asking to upload .trk* file.
December 19, 2024 at 11:58 am
Forum ModeratorAnswered here  https://innovationspace.ansys.com/forum/forums/topic/tracking-of-a-particle-velocity-vector-of-spray/ Creating new topics rather than waiting is a really good way to annoy the Moderator team.Â
5819
