TAGGED: cfd-udf-fleunt, fluent-udf-multi-phase, udferror
March 11, 2025 at 2:53 am
raju.chowdhury
SubscriberHi,
I am working on an E-E multiphase model to simulate heat transfer between the phases. I am using the following UDF to apply a temperature-dependent density profile of the secondary phase.
#include "udf.h" #include "math.h" DEFINE_PROPERTY(cell_density,c,t) { real g_density; real temp; /* density of secondary phase */ Thread *phase_thread = THREAD_SUB_THREAD(t, 1); temp = C_T(c, phase_thread); if (temp > 273.0) g_density = 522.478 * pow(temp, -1.014); else g_density = 1.63; return g_density; }
While compiling, no error displays; however, while initialising the solution, getting the following error. Not sure where is the problem. Any suggestions will be great.
Node 4: Process 45008: Received signal SIGSEGV.
Node 5: Process 47176: Received signal SIGSEGV.
Node 0: Process 44496: Received signal SIGSEGV.
Node 3: Process 5776: Received signal SIGSEGV.
Node 2: Process 48580: Received signal SIGSEGV.
Node 1: Process 53732: Received signal SIGSEGV.
999999: mpt_accept: error: accept failed: No such file or directory
= Â BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= Â RANK 0 PID 44496 RUNNING AT CNA309-6LJDRZ2
= Â EXIT STATUS: -1 (ffffffff)
= Â RANK 4 PID 45008 RUNNING AT CNA309-6LJDRZ2
= Â RANK 5 PID 47176 RUNNING AT CNA309-6LJDRZ2
 The fl process could not be started.Error: Invalid result name.
Error Object: () -
March 11, 2025 at 10:04 am
Forum ModeratorI'm not sure you need to assign the phase thread for properties as it's a material property.Â
March 11, 2025 at 10:10 am
raju.chowdhury
SubscriberAs I have used temperature-dependent density variation, which temperature will it consider (primary or secondary phase) to calculate the density?
March 11, 2025 at 10:22 am
Forum ModeratorIt should be the material temperature - try it and see what you get.Â
March 11, 2025 at 10:24 am
raju.chowdhury
Subscriberokay. I will try that.
March 11, 2025 at 11:51 am
raju.chowdhury
SubscriberDo I need to add any command for running the simulation using parallel nodes in HPC?
March 11, 2025 at 12:04 pm
Forum ModeratorNot for the UDF, you only need the NODE/HOST calls for sum loops (it's covered in the Parallel considerations chapter). You may or may not for the solver based on your IT cluster configuration: that's for local IT to advise.Â
- affinity not set
3907
1414
1256
1118
1015
