July 11, 2024 at 3:37 pm
mario.clemente
SubscriberI use HFSS for my model in frequency domain, working without problem. After that, when I use circuit design and export my model (see figure ) for study in time domain and plot eye diagram.
The simulation crashed presenting this error : "models:s_element(warning): fieldsolver:133.s - S-parameter data is not passive. Worst violation of 0.000100943 at 600000 (Hz).Â
July 15, 2024 at 7:48 pm
Dan Dvorscak
Ansys EmployeeHmm, that passivity violation alone should not have caused the entire simulatoin to fail. Can you show the rest o fthe simulation messages? It also may be worth turning on passivity enforement just to be safe. To do that right mouse click on the s-parameter component, and select Edit Model. In the form that comes up go to the Options tab and set the passivity enforcement option to "IFPV".Â
- The topic ‘Error in time domain using EYE SOURCE and EYE PROBE’ is closed to new replies.
5939
1307
