March 31, 2024 at 8:19 am
abdullahhassan
SubscriberHello,
I want to add a saturated ammonia table (Temp vs Pressure) for evaporation-condensation of ammonia.Â
As per guidance from ANSYS help , image attached below, i tried to input a table in ansys fluent
The below image shows my input in ANSYS Fluent > User defined > read table > table file manager > read .Â
I tried multiple ways to input this data, check the directory name, i am getting below mentioned three errors for different variation but the table is not loading in ansys.
Please guide me in this matter.Â
April 2, 2024 at 12:29 am
abdullahhassan
SubscriberDear Team,Â
Kindly guide me in this matter. Looking forward for your reply.Â
Thankyou.Â
April 2, 2024 at 2:51 pm
Forum ModeratorWhat does you data look like in WordPad? Are there any white space characters in the file?
April 2, 2024 at 10:28 pm
abdullahhassan
SubscriberDear Rob,Â
It have put my data in excel and then read the table in ANSYS.
But now, i just put my data in wordpad. below is the image.
There is no spaces before and after Psat or Tsat etc. but one error i recieved is ",invalid column Psat"
Other errors are "EOF in string read" etc.Â
You can see the errors in above post. there are total three different errors i recieved when i read tables with different setting.
April 3, 2024 at 9:00 am
Forum ModeratorYes, write out csv and see it that works. It's very easy to get white space characters that confuse the Fluent data readers.Â
April 4, 2024 at 7:53 am
April 4, 2024 at 10:57 am
Forum ModeratorPick one with no white space characters and no commas.Â
April 6, 2024 at 3:14 am
April 8, 2024 at 9:10 am
Forum ModeratorWhat is different between your table and the example in the manual?Â
If you manually type in a few rows of data does that work?Â
April 9, 2024 at 9:36 am
abdullahhassan
SubscriberI am just using saturation ammonia table. The table format is same, I follow the instructions online.Â
Maybe there is some issue while converting .xlsx file into .csv .
I tried converting .xlsx format into .csv ONLINE this time.Â
Luckily, after reading the file into ANSYS, it is showing now (as shown below), previously, i was unlucky in this.
but still i get this error.Â
April 9, 2024 at 10:05 am
Forum ModeratorThe error means there's missing setting, basically you have a blank field somewhere. So, now the table reads in OK look through the rest of the set up.Â
April 15, 2024 at 2:50 am
abdullahhassan
SubscriberThank you so much Rob for your help.
The issue is resolved. as you said before, tried to open the file in wordpad. I opened it and saved the file in .txt format. then i read the table in ANSYS and it works fine.Â
- The topic ‘Error in Table input into ANSYS Fluent.’ is closed to new replies.
6269
