April 12, 2024 at 9:33 am
April 15, 2024 at 4:43 am
Fazalul Chemban
SubscriberÂ
I kindly request ansys employees to comment on this error.
April 15, 2024 at 1:08 pm
Ashish Khemka
Forum ModeratorHi, by SVD are you referring to  singular value decomposition? Also for second error - are you applying displacement directly at a location where there is a constraint equation (say a remote force etc.)?
Ashish Khemka
April 16, 2024 at 12:54 am
Fazalul Chemban
SubscriberÂ
Based on my understanding it would be singular value decomposition. Initially, I thought it would be error corresponding to calculation related to solver and tried different solvers but it didn’t helped. Do you have any solutions for SVD error, I will try executing.
I am doing modal analysis and not applying any displacement directly at a location where constraint equations are applied. I kindly request to suggest resolution at the earliest as my deadline is very tight. Thanks for your help.
April 16, 2024 at 2:45 pm
dlooman
Ansys EmployeeThere is no prior report of this error in our call tracking system which goes back over 10 years. It does seem to be a fundamental modal solver error. To determine the node numbers associated with an internal constraint equation issue the command celist,,,,conv immediately after the solve command and then save the database. celist,,,,conv converts the internal constraint equations into external constraint equations which can be listed with celist,,,,conv. If you are able to create a service request for this that would be desirable.
- The topic ‘Error in SVD and constraint equation.’ is closed to new replies.
5794
