Error in SPH calculations
    • cma6301
      I am trying to look at particle-fluid interaction. Hence am using SPH in ROCKY to represent my fluid. I use default setting only changing element size to 3times lower than my smallest particle size.
      The simulation starts running after some time(a day or two) it prints this error attached
    • jackson.dasilva
      Hi cma6301,
      That error might be related to several factors. Here are a few things you could check:
      1. File name length: Make sure the file name isn’t too long or contains any unusual characters.
      2. Disk space: Ensure that your disk isn’t full, as this could lead to issues when the simulation tries to create or write files.
      3. File permissions: Ensure that the simulation has permission to write or create new files.
      Best Regards
