October 26, 2022 at 1:59 am
Marie Palau
SubscriberHi all,
I´m having the following error with my simulation. Does anyone knows how to fix it? I'd really appreciate any help.
/COM,ANSYS RELEASE 2022 R1 Â Â Â Â Â BUILD 22.1 Â Â Â UP20211129 Â Â Â 20:50:24
 *** WARNING ***             CP =    0.828  TIME= 20:50:24
 Element shape checking is currently inactive.  Issue SHPP,ON or     Â
 SHPP,WARN to reactivate, if desired.                  Â *** WARNING ***             CP =    0.984  TIME= 20:50:25
 Material number 2 (used by element 60119) should normally have at leastÂ
 one MP or one TB type command associated with it.  Output of energy by Â
 material may not be available.                     ÂÂ
I know it says they are warnings, but my ansys is crashing each time and it closes the study.
Thank you so much!!!
October 26, 2022 at 12:57 pm
mrife
Ansys EmployeeHi @Marie Palau
Workbench Mechanical does element shape checking when it meshes, so it turns off shape checking by Mechanical APDL (the solver) as it is redundant. Â
The material warning is for a contact element in the model. Contact elements don't necessarily need material properties as they use the properties from the regular element they are attached to. Now there are a few contact features that would result in a material model used by the contact element like friction (friction coefficient defined by material model). But that is the exception and not the rule.
So, what do you mean by crashing? At what step does that happen? Are there any pop-open windows when that happens (normally a notice that a dmp file has been written)?
Mike
October 27, 2022 at 5:38 am
Rachel Gomez
SubscriberTroubleshooting Tips and Techniques
Simscapeâ„¢ simulations can stop before completion with one or more error messages. This section discusses generic error types and error-fixing strategies. You might find the previous section, How Simscape Simulation Works, useful for identifying and tracing errors.If a simulation failed:
Review the model configuration. If your error message contains a list of blocks, look at these blocks first. Also look for:
Wrong connections — Verify that the model makes sense as a physical system. For example, look for actuators connected against each other, so that they try to move in opposite directions, or incorrect connections to reference nodes that prevent movement. In electrical circuits, verify polarity and connections to ground.
Wrong units — Simscape unit manager offers great flexibility in using physical units. However, you must exercise care in specifying the correct units, especially in the Simulink-PS Converter and PS-Simulink Converter blocks. Start analyzing the circuit by opening all the converter blocks and checking the correctness of specified units.
Try to simplify the circuit. Unnecessary circuit complexity is the most common cause of simulation errors.
Break the system into subsystems and test every unit until you are positive that the unit behaves as expected.
Build the system by gradually increasing its complexity.
It is recommended that you build, simulate, and test your model incrementally. Start with an idealized, simplified model of your system, simulate it, verify that it works the way you expected. Then incrementally make your model more realistic, factoring in effects such as friction loss, motor shaft compliance, hard stops, and the other things that describe real-world phenomena. Simulate and test your model at every incremental step. Use subsystems to capture the model hierarchy, and simulate and test your subsystems separately before testing the whole model configuration. This approach helps you keep your models well organized and makes it easier to troubleshoot them.
Rachel Gomez
- The topic ‘Error in simulation’ is closed to new replies.
2778
965
841
599
591
