Ansys Products
Ansys Products
Error in PrePost Script provided in Rocky tutorial for SAOR
    • abu.hamad
      Hi, I am performing static angle of repose tutorial available in rocky (dem_tut02_files). In the Post processing when i run the Pre-script code which is given in tutorial files, there is following error which can be seen in the attached figure (error: unknown particle grid function). I do everything same such as its mentioned in tutorial guide but it has error. In addition, i dont know posting here is called "create ticket" or its somewhere else. Actually, i want to to attach error report also but here i am not able to do this. I will be thankful if you can solve my issue. Thanks
    • jackson.dasilva
      Hello, Abu.hamad
      Make sure you are using the last version of the script. Please go to Current Release , select the release version and download the additional package on Add-On Packages.
      Best Regards.
    • oskarphilip.lewitzky
      I had exactly the same problem,
      Here is the link to the ANSYS help tutorial, that uses the updated script:
       Chapter 2: Tutorial - Static Angle of Repose Test
      ANSYS provides a link to download the new script under 2.1.4. PROJECT CREATION.
      Best Regards
