Electronics
Electronics
Error in OptiSlang
    • sree-ranjini.kizhakkethil-swaminathan
      Output parameters are not computed in OPTISLANG while using an intermediate python script with MCAD. I am trying to do sensitivity study of IPM machine by using intermediate Python script, however some of the output results are not computed . I checked the design feasibility manually of that design. Geometry is feasible in MCAD and Avergae torque is not zero. What could be the reason for this?
    • HDLI
      Hello Sree,
            Could you how you get the average torque in Maxwell and if time range has an issue? If not, could you check if you can get other results correctly in optiSLang in this design point? Thanks.
      HDLI
      I am using MOTORCAD not Maxwell.
    • HDLI
      Hello Sree,
              OK. Thanks. Could you check if this design is run and completed in optiSLang? Could you rerun it?
      HDLI
  • The topic ‘Error in OptiSlang’ is closed to new replies.
