March 19, 2021 at 12:46 pm
Bobby11
SubscriberWhy motor torque is falling by ~3Nm by simulating only one pole of motor compared to full motor?
I have also appropriately given boundary condition. Please help.
March 19, 2021 at 3:05 pmNKC
Forum ModeratorHi @Bobby11,nCan you check if you have exactly the same Analysis setup for both conditions?nRegards,nNavyan
March 20, 2021 at 6:11 amBobby11
Subscriberyes ..i have same settings. nMarch 22, 2021 at 4:51 pmHDLI
Ansys EmployeeHello Bobby11,n It is an interesting question and we may check everything in both model. Here is some information. nGeometry. Could you check the if the one pole geometry can present the full geometry? In the one pole model, do you use Master/Slave or Independent/Dependent, and Bs = - Bm , Bdep = -BinpnMaterial. Please use the same materials and magnet directionnMeshing. Please use the same meshing and improve the meshing to achieve the accurate results.nCheck the length and skew option in Design setting.nCheck the excitation and Setup's setting.n The results should be same if the one pole model can present the full geometry. Thanks.nnViewing 3 reply threads- The topic ‘Error in motor torque computation with 1Pole’ is closed to new replies.
Innovation SpaceTrending discussions- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
Top Contributors-
4062
1487
