September 20, 2022 at 11:03 pm
agarwa20
SubscriberHello,
I was running stress analysis in Ansys Mechanical. For running multiple cases I created a parametric variation. I am using the Nissan Leaf motor model (shown below) I obtained from the Ansys learning hub. The thickness of the I and V shape magnets are the parameters. I am considering stresses only on the hole edges.Â
Based on a response surface based DoE, only three designs were successfully evaluated. For the three design points which were successfully evaluated I manually ran the stress analysis for those cases. However, I observed that the results were different from the DoE based stress.Â
I have also checked the case where stress is checked for the entire rotor body. However, I observed that the DoE based iterations gave much higher stress values than the ones I obtained with manual iterations for the same design points. In order to further check this, I took the rotational velocity as a parameter instead of the width of the magnets. In this case the DoE based results matched with the manually checked results. Am I making a mistake here? Is it feasible to perform a geometric parametric study in Ansys Mechanical?
Thank you.
September 21, 2022 at 1:16 am
peteroznewman
SubscriberWhich geometry editor are you using to have a width parameter on the magnet?
In my experience, DesignModeler is safer for shape changes than SpaceClaim.
September 21, 2022 at 1:54 am
September 21, 2022 at 5:35 pm
peteroznewman
SubscriberSorry, I don't know anything about Maxwell goemetry engine and I don't have that software installed. I hope someone else will reply.
- The topic ‘Error in Mechanical- Spurious stress results from geometric parametric variation’ is closed to new replies.
5899
1306
