January 24, 2024 at 4:18 pm
Curtis Steele
SubscriberOur LS-Dyna license expired toward the end of last year. We obtained a new license, but are still having issues getting it working. I renamed the new license to server_data with no extension, stopped the server service, copied the new server_data into the proper folder, and restarted everything. After logging in, I get this error message when I try to check the new license status:
Last time I got this message, I had to get a new license. I was hoping someone could check the license to see if it looks OK (see below):
Northern Illinois University -- 1126169
  EMAIL: NONE
   FAX: ++++
TELEPHONE: ++++
MPPDYNA Â Â Â Â 09112024
 OPTION: ISSUED julian.ware_09122023
 OPTION: REVISION 14
MPPDYNA_971 Â Â 09112024
 OPTION: REVISION 6
MPPDYNA_970 Â Â 09112024
MPPDYNA_960 Â Â 09112024
LS-DYNA Â Â Â Â 09112024
 OPTION: REVISION 14
LS-DYNA_971 Â Â 09112024
 OPTION: REVISION 6
LS-DYNA_970 Â Â 09112024
LS-DYNA_960 Â Â 09112024
MACHINE: C6 78 4C BB 5ED70587 C1187159 68C465D4 3E13B456
KEY: 0D D9 C8 FA B7 16 8B AD 52 E2 84 B2 8C B7 65 B0
#KEY2: 27 5A 12 51 04 28 9C 35 5A F5 01 1A 32 CD E0 2A
#KEY3:AAFDAAAAWlDgJSYOxhelwjRoggm0WsTt2isKl0ZhQQpqUA9zYUxRruF/1GZ6Egf6b3h+koNvsrJ4
#KEY3:EhdhIlDl6esWx32gfxg/XEmUHBErSbTDcZRCTlzmc9t0YNrDZNcJyCWoEvRF4noBduK/k1J6Z30Y
#KEY3:/TbrJ7U1hScwqYVw0W9PYJiDJXREz6E0wK1/GWhtBGU+wRdQnOdTLZXR1i3IqU1Q82j6TpDCKCQY
#KEY3:kxtDR9E5IVzqA0YLu14PtfovJIJNeHQZuPJ5gQ3Wf7kOjwiYg6oJCRW2ZOL1oTThlkI7vaj5Od5O
#KEY3:kjcHsHIny01QZz484B014/tXjdhXRAgihBTbbVsIDOl+euJZtCD2IERhAQAAAA==
#KEY4:AAJDAAAAi1pNA4gF4h9sJRdddGI6Ibdz/GdwOLhFejbgCvB57g3Ii1NQa/IEZvOQ43LSD/oo4a7/
#KEY4:dXrWrGb/IL9zjPisAiQ0ZVE451hrVEpfMgZCHEN/NFEave3jLEX8v2LLy71dyYr/dierFFKPtP1s
#KEY4:rkMwFYBkfDvNfKxQ73jRSFVuVg9rs/ERe0HzTX7DqV7gtdsUUeJ5VI560QcKcQ15G33aX5DIAAU7
#KEY4:qtIUFpCyFHKKjlnSQWxaIn0BQOfFe139oip2OdCYcSGVTl/BUI4FZ0SeOZwzOCUuN41Jh803NleK
#KEY4:qhLk5Bh4natyeUUnMU07lHZzIA4KZ199TESGueNwgnAAZ8K4amj1bpshAwAAAA==Â
January 25, 2024 at 4:11 pm
igandiko
Ansys EmployeeThe MACHINE field above should be SERVER for network license. Only nodelocked licenses have MACHINE entries. If Ansys sent you the license with MACHINE entry, please generate LSTC_SERVER_INFO file again and send it over to the license team. Make sure LSTC_SERVER_INFO shows SERVER entries.Â
- The topic ‘Error in LSTC license configuration file?’ is closed to new replies.
4597
1495
1386
1209
