October 25, 2024 at 10:08 am
thamilmani
SubscriberI usually use pyfluent scripts for postprocess.
Some of my cases always load up correctly in GUI. But when opened in terminal (-g) or through pyfluent script, It throws this error.===============Message from the Cortex Process================================ÂError at Node 0: Unable to open ../case-data/103/M1-S2-new-Full-Kong.cas.h5 for reading.ÂCompute processes interrupted. Processing can be resumed.Â==============================================================================ÂAny idea why? Any help would be appreciated.And its not for all the cases. This case has a UDF to load which also loads correctly.ÂI am running the script in a WSL Ubuntu 24.04. -
October 28, 2024 at 1:14 pm
Federico
Ansys EmployeeFor PyFluent related questions, I would suggest you try the Developper Forum: Home - Community Forum
1306
