May 19, 2024 at 8:34 pm
uddin43
SubscriberHi,
I am facing an error related to heat transfer between interfaces. I am trying to run the simulation in cluster processor. I have used simply two cubes with a common interface. I shared the topology and maintained coupled interface wall. In local Ansys it is running smoothly. However activating energy equation, the cluster Ansys is showing the following error:
Error: Set_Thread_Variables: wta(real)
Error Object: ((constant . 0) (profile "" ""))
Error encountered in critical code section
I am not using any UDF just simple coupled heat transfer and with different velocity inlets temperature. I have checked geometries and tried many ways. This issue is arising only when energy equation is activated with an interfacial coupled wall. Where is the problem then, kindly help. -
May 20, 2024 at 11:07 am
Forum ModeratorPlease can you post some images of the set up? Including the coupled wall settings and boundary condition list.Â
May 20, 2024 at 11:33 am
uddin43
SubscriberÂ
Hi Rob,
My actual problem is a shell and tube heat exchanger. But for finding the error, I simply generated the following cube setup. All the boundary conditions are shown in the below picture. I am also sharing the journal and shell files I have used. As I said, in local ansys the simulation is running with no errors, but the cluster is showing the error just after reading the boundaries, I have also attached the image of that. Kindly help.
May 20, 2024 at 1:12 pm
Forum ModeratorLooks OK. Can you initialise & run locally? Check the other wall boundary settings, and what is set on the outlets.Â
May 20, 2024 at 1:18 pm
uddin43
SubscriberYes, it is working fine locally and providing results with non-conformal mesh also. However, I need to run this on cluster. Any more suggestion?
Outlets are simple pressure outlet with guage pressure 0 and walls are no slip walls with 0 heat flux. -
May 20, 2024 at 1:32 pm
Forum ModeratorThat's not a nonconformal interface, it's a conformal coupled wall. There's nothing in the journal that could be causing a problem, can you run on the cluster via GUI? What parallel settings are you using, and how many cores?
May 20, 2024 at 1:44 pm
uddin43
SubscriberI understand it is a conformal mesh. In local ansys both conformal and non-conformal is working. In cluster, without activating energy equation, it is working fine. However when energy is activated, its not working. I am using 1 node 32 cores for the cluster. The parallel settings are mentioned in the bash file attached above.
May 20, 2024 at 1:56 pm
Forum ModeratorThere's nothing in the model that should cause a problem. Have you tried running on fewer cores? Which version are you running on?
May 20, 2024 at 6:23 pm
uddin43
SubscriberThank you Rob. The issue was with version. I was using a higher version of Ansys locally and changing my version worked properly. Thank you for your time and support.Â
May 21, 2024 at 8:38 am
Forum ModeratorThat'll explain it. Newer cases may read into the older solver, but occasionally things don't quite work right.Â
- The topic ‘Set Thread Variable Error when running in cluster’ is closed to new replies.
5649
1885
1404
1303
