April 19, 2024 at 10:41 am
yogesh.babu
SubscriberI'm getting this error "Anstranslator failed to generate initial configuration" whenever I try to import a .dxf file to Ansys from Autocad. Does anyone know how to resolve this?Â
TIA
May 2, 2024 at 6:37 am
Praneeth
Ansys EmployeeHi,
Thank you for reaching out to the Ansys learning forum. Your patience on this is much appreciated.
Are you referring to Ansys Electronics Desktop? If so, please let us know which design type you are using to help us serve you better.
Best regards,
Praneeth. -
May 3, 2024 at 8:17 am
yogesh.babu
SubscriberHi Praneeth,
Thank you for your reply.Â
Yes, I'm using AEDT, HFSS design type. The issue is now fixed.Â
Kind regards,
Yogesh
May 3, 2024 at 8:23 am
Praneeth
Ansys EmployeeHi Yogesh,
Thanks for your reply. It is great to hear that the issue is fixed.
If possible, please share how the issue was fixed for future reference.
Best regards,
Praneeth.Â
May 3, 2024 at 8:37 am
yogesh.babu
SubscriberSure. I tried to import the dxf file saved as Autocad 2013 dxf version and it worked without any error. However, with Autocad 2018 dxf version, it gives the above error.Â
May 3, 2024 at 8:40 am
Praneeth
Ansys EmployeeThanks for posting the answer. Keep up the good work.Â
October 2, 2024 at 10:43 am
poojap
SubscriberÂ
I am using Autocad 2025 version , and i tried exporting .DXF file in Autocad 2013 version , still getting error in Ansys Electronics. Please help me out
Thank You
- The topic ‘Error in importing dxf file from Autocad’ is closed to new replies.
6344
