January 7, 2019 at 8:31 pm
Julia
SubscriberHello,
I am receiving the following error when I try to analyze a circuit with a dynamic link to an HFSS design. I would appreciate any advice regarding the origin of this error and if there is anything I can do to avoid it.
Thank you!
RFWireless_12212018_SweepSizeAndPosition_HumanAvg (/home/jeb113/Ansoft/)
 Circuit1
   [info] Nexxim simulation will use local parameter scoping. To change this option, please go to Tools>Options>General Options>Circuit Design (3:26:00 PM Jan 07, 2019)
   [info] (info): Processing circuit for new analysis. (3:26:00 PM Jan 07, 2019)
   [error] parser(error): /home/jeb113/Ansoft/RFWireless_12212018_SweepSizeAndPosition_HumanAvg.aedtresults/Circuit1/temp/DV40_S35_V56.cir:22: Unrecognized line type (not device or .card) (3:26:00 PM Jan 07, 2019)
   [error] parser(error): /home/jeb113/Ansoft/RFWireless_12212018_SweepSizeAndPosition_HumanAvg.aedtresults/Circuit1/temp/DV40_S35_V56.cir:25: Unrecognized line type (not device or .card) (3:26:00 PM Jan 07, 2019)
   [error] (error): Error found during loading: analysis aborted for /home/jeb113/Ansoft/RFWireless_12212018_SweepSizeAndPosition_HumanAvg.aedtresults/Circuit1/temp/DV40_S35_V56.cir (3:26:00 PM Jan 07, 2019)
   [error] (error): Some or all simulation failed for /home/jeb113/Ansoft/RFWireless_12212018_SweepSizeAndPosition_HumanAvg.aedtresults/Circuit1/temp/DV40_S35_V56.cir. Total simulator time: 0:00:00 (3:26:00 PM Jan 07, 2019)
January 8, 2019 at 6:24 pm
Sorceress Gia
Ansys EmployeeHi Julia,
Try deleting the dynamically linked HFSS component from the Circuit Schematic, saving the model, and then re-drag and drop the HFSS model back into the Circuit Schematic. Re-run the circuit simulation again and see if the error has been resolved.
Best,
January 8, 2019 at 7:09 pm
Julia
SubscriberThat worked, thanks!Â
July 20, 2020 at 9:28 pm
Julia
SubscriberHello,Â
I'm getting the same error again. I've redrawn the circuit schematic in addition to the above advice.Â
Any help would be greatly appreciated!Â
March 28, 2022 at 3:45 pm
mona4
Subscriber.- If you had set up a frequency sweep in HFSS project and then disabled the sweep , the default analysis data remains on frequency sweep and scince there is no sweep it couldn't find the simulation data in circuit project.Â
In this case you can change this default under the circuit project tree:Â
- Â Expand the tree hierarchy under the HFSS icon in the project tree.Â
- Select LastAdaptive instead of Sweep.Â
March 29, 2022 at 3:02 pm
Dan Dv
Ansys Employee.That "Unrecognized line type (not device or .card)Â " error implies that something went wrong on the netlist level. Sometimes that can happen if an illegal character is used in a node or model name. If you can right mouse click on the Circuit analysis setup in the Project Manager and select "browse netlist" you can see the netlist that gets sent to the Circuit solver. If you show that here, or just the lines that are getting flagged in the error message, that might give us a better idea what is going wrong.
- The topic ‘Error in HFSS-Circuit Dynamic Link Analysis’ is closed to new replies.
3572
1188
1076
1063
952
