August 2, 2024 at 6:00 am
pavan kumar
SubscriberHi, I am trying to do mesh the following geometry in cyclic symmetry boundary conditionÂ
these are mesh parameters i used
However, I am always getting the error: Mesher failed to mesh topological edges.Â
error :One or more entities failed to mesh. The mesh of the bodies containing these entities may not be up-to-date. Â However, meshing might be successful on the other entities.
error : A mesh could not be generated using the current meshing options and settings.
error: One or more objects may have lost some scoping attachments during the geometry update. You can identify these tree objects by filtering the tree using the Scoping option set to Partial.
i tried all the possible ways to do meshing but still im not done the meshÂ
Does anyone know any solutions to this?
and here i attached the file also please go through the file and do the needfulÂ
I am using the version is ANSYS 2019 R3.
Thanks in advanceÂ
August 7, 2024 at 6:53 am
Kaushal Vadnere
Ansys EmployeeHi Pavan,
We have a similar discussion with solution to 'error: Mesher failed to mesh topological edges' here: Mesher failed to mesh topological edges (ansys.com)
See if this helps.
6535
1311
