April 23, 2024 at 12:37 pm
abhinavraotr
Subscriberin the create regions section of ansys fluent. I have encountered a problem of not being able to creat them the error code for the same is,Â
Error: state/object/execute-command:Exception encountered in S_ExecuteTask: One or more zones (2059 1887 1958) are not part of a volumetric region. Ensure all openings are properly capped.
Please help me diagnose the problem and fix the issue. I have checked my geometry and found that no openings appear to be open. Your help will be appreciatedÂ
April 23, 2024 at 12:53 pm
Forum ModeratorPlease post some images of the geometry and what Fluent Meshing thinks it's meshing.Â
April 23, 2024 at 1:35 pm
April 23, 2024 at 2:32 pm
Forum ModeratorCan you check you don't have surfaces between the pale and dark blue zones? What does the SpaceClaim geometry look like?Â
April 23, 2024 at 4:01 pm
April 23, 2024 at 4:05 pm
Forum ModeratorAnd that's one solid/volume? Yes, Discovery is more-or-less the same as SpaceClaim so should behave the same. Â
April 24, 2024 at 2:12 am
abhinavraotr
Subscriberyes, that is one single solid.Â
April 24, 2024 at 10:28 am
Forum ModeratorCan you check for small surfaces around the surface joints? Or check your local sizing - you shouldn't have so much mesh clustering around the diameter changes.Â
April 24, 2024 at 10:59 am
abhinavraotr
Subscriberthank you for the advise i checked and there was a small gap between the 2 faces so i fixed that andnow my simulation is working fine.Â
- The topic ‘ERROR IN CREATING REGIONS IN WATERTIGHT GEOMETRY ANSYS FLUENT WITH MESHING’ is closed to new replies.
5824
