Error in correction factor
    • Odniel Mahadika
      Hi everyone,
      I am using Aqwa 2021R2, I got an error in correcrion factor when I start to solve the solution in aqwa, I don't know what's causing the problem, could anyone help me?
      Thanks
    • Ingrid M
      could you please check the geometry of these mesh elements IDs (you can view them using the AqwaGS)?
      This is likely a matter of element size or shape (ie, these elements have a twisted shape and they are not on the flat plan).
  • The topic ‘Error in correction factor’ is closed to new replies.
