February 15, 2022 at 5:00 pm
antonio.ammendola
SubscriberHi all,
I'm trying to do a convection model with moisture involved. When I setted all the parameters and tried to make a Hybrid Initialization the program gave me this error:
Error at host: malloc_shared_storage: unequal sv_lengths, thread 82, SV_STATUS.
Can you help me, please?
February 15, 2022 at 5:09 pmRob
Forum ModeratorHow much RAM have you got, and how many cells in the model? A malloc error is memory allocation so tends to mean you need a bigger computer. There are other causes, but that's the most common.
February 15, 2022 at 5:14 pmantonio.ammendola
SubscriberHi have a RAM of 32GB, With a mesh of around 3000000 cells.
Cosider that I've made already a model only for temperature distribution and it works very well. Like half an hour and I've the results
February 16, 2022 at 1:42 pmRob
Forum ModeratorThat should fit OK. What's different in this model if you've already modelled heat transfer? Have you got any UDFs in the case?
February 16, 2022 at 3:36 pmantonio.ammendola
SubscriberNo no i haven't fitted any UDFs. I run the model only with the heat transfer, without water vapor, only with air inside. Now I want to add water vapor and see if there are condensation fenomenon on the surface of the dominium. In order to do that I tried to add at the previous model the multiphase model (volume).
February 16, 2022 at 5:57 pmRob
Forum ModeratorYou had a single phase model then switched on multiphase? Which model? Are you wanting to model free stream or surface condensation?
February 20, 2022 at 6:40 pmantonio.ammendola
Subscribervolume of fluid. I wanted to model surface condensation
February 20, 2022 at 6:52 pmantonio.ammendola
Subscriberand yes i swiched from single to multiphase
February 21, 2022 at 12:31 pmRob
Forum ModeratorMultiphase uses a slightly different data structure so the results you already have may not be valid with the current set up. You can get around this with an interpolation file. For surface condensation I'd also read up on the wall film models: VOF will be a very mesh intensive way to model condensation.
February 21, 2022 at 2:04 pmantonio.ammendola
SubscriberSo If i start another simulation from the beginning, using wall film model, I have to do an interpolation file anyway? Is possible to use Radiation model and multiphase model together? There are some tutorials that I can follow in ansys guide or something like that?
February 21, 2022 at 5:43 pmRob
Forum ModeratorWall film will run on from single phase as it's not a multiphase model. VOF won't, but you can interpolate the old data back onto the new set up assuming there isn't much/any of the other phase to consider.
Multiphase will generally work with radiation, but check the model compatibility and limitations.
February 21, 2022 at 7:03 pmFebruary 22, 2022 at 4:41 pmRob
Forum ModeratorSet the film initial condition, leave the Film boundary condition alone.
February 24, 2022 at 12:42 pmantonio.ammendola
SubscriberOk thanks. I've tryed but wen i initialize the case appear this message
===============Message from the Cortex Process================================
Compute processes interrupted. Processing can be resumed.
Do you know why?
February 24, 2022 at 3:12 pmRob
Forum ModeratorDid you initialise the film from the EWF panel? It's an odd set up and is separate from the rest of the solver initialisation.
February 25, 2022 at 12:03 pmantonio.ammendola
SubscriberYes, i enabled the wall film from the boundary condition and then i changed fron boundaty to initial condition, setting all to 0. then i initialised the case from the EWF setup. But always appear this error message.
February 25, 2022 at 12:06 pmFebruary 25, 2022 at 12:08 pmFebruary 25, 2022 at 2:12 pmRob
Forum ModeratorTurn off the scalar and re-try.
February 25, 2022 at 2:44 pmantonio.ammendola
SubscriberI'sorry for bothering you again but i've done what you suggest to me but i obtain the same error message
February 25, 2022 at 4:11 pmRob
Forum ModeratorIt's no bother. Shouldn't the film be water-liquid? Otherwise where does the latent heat go? Otherwise what you've shown looks fine. Try initialising from a flow boundary in case there's something odd being set in the hybrid scheme for the initial data.
February 28, 2022 at 9:03 amFebruary 28, 2022 at 4:40 pmRob
Forum ModeratorNot sure, turning off surface tension shouldn't do anything to the film other than stop it beading up.
March 1, 2022 at 11:36 amViewing 23 reply threads- The topic ‘Error in convection model’ is closed to new replies.
