Error in CFX Solution
    • AS10
      Hello Everybody,
      I got this following error in the CFX-Solver: "The ANSYS CFX solver exited with return code 1. No results file has been created." and "Update failed for the Solution component in CFX. The solver failed with non-zero exit code of 2"
      Can someone help me, to fix this error? I have got a Workbench Archive file.
       Kind Regards
    • DrAmine
      ANSYS Staff do not download attachments. Please insert the lines here. The error message might be caused by a lot of things. You can off course share whatever you like but ANSYS Stuff would not download these attachments.
      Can you describe your case please?
    • AS10
      Thank you for the fast Response. I want to simulate an F1 Frontwing. But now I have the Problem to get the results (solution)--> to run the solver.
      I got the error shown: "The solver failed with non-zero exit code of 2"
      In the following there are the whole Error and mesh description: I hope that is helpful:
      My Systeminformations are: Surface pro 6, Windows x64, Intel Core i7, 16GB RAM
      Best regards
    • DrAmine
      Go to the partitioner part any messages? CFX is complaining about mapping regions.
      Please add screenshot of geometry details domain definition from Pre.
    • AS10
      I got a Inlet --> Normal Speed: 190 km/h; Outlet: Average Static Pressure: 0Pa; Top: No slip Wall; Frontwing: No slip Wall; Symmetry: two sides.
      Here are the screenshots:
    • AS10
      and Partitioner part:
    • DrAmine
      I meant partitioner part in the outfile. Do you see any errors in Pre? Can iyou u check if the fluid domain is consistent? Give the fluid domain a name in meshing.
      SAS is a SRS approach it requires CFL smaller than 1 and LES grid whereever you want to resolve the flow.
    • AS10
      Hallo, i will be out of Office until Monday. In that time i don't have Internet, to communicate. I will give you the required informations on Monday. Thanks for your big help.
    • DrAmine
      Welcome.
Viewing 8 reply threads
  • The topic ‘Error in CFX Solution’ is closed to new replies.
